Uncertifiable!!!
Uwon's Avatar
Adjusting Older Koni Shocks-Help
I have these 15 year old adjustable Koni shocks (#1214) that I want to instal into my RST build but quite frankly I cannot remember how to adjust them. They have a ball bearing type valve with a small pin hole in it located at the top of the body which does not resemble the illustrations in any of the Koni websites. As well, I cannot get any clicking sound when the body is turned with the unit fully depressed. Any ideas?
Thanks in advance.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 10-05-2015, 08:04 PM
Uncertifiable!!!
Uwon's Avatar
Here is a pic....
Johan
Old 10-06-2015, 12:18 AM
cycling has-been
bkreigsr's Avatar
The red ones are adjusted by cycling them to full compression, then engaging a captured nut in the bottom of the tube. Clockwise for firm, counter-clockwise for softer.
You only get about a 1 1/2 turns, full-soft to full-firm.
I suggest dropping an email to Koni customer service regarding the ball valve.
Bill K
Old 10-06-2015, 07:49 AM
tobluforu's Avatar
http://www.koni.uk.com/home/index.php?option=com_content&view=article&id=83
If I remember, you press the button, start turning, let go and it snaps back up into place?
No idea if this helps.
Old 10-06-2015, 08:09 AM
Uncertifiable!!!
Uwon's Avatar
Originally Posted by tobluforu View Post
Monotube Adjustment - Koni U.K
You are absolutely correct. Many Thanks tobluforo
Old 10-06-2015, 12:39 PM
