-   -   Rear view mirror glue (http://forums.pelicanparts.com/porsche-911-technical-forum/885554-rear-view-mirror-glue.html)
matt gineo 10-03-2015 12:20 PM
My one year old grandson loves to drive my 76- 911 and while doing so last week he pulled off the rear view mirror. Any suggestions on the type of adhesive to use to reattach it? It appears to be one single unit, unlike the modern mirrors with a detachable button mount.
thankshttp://forums.pelicanparts.com/uploa...1443899909.jpg
DaveMcKenz 10-03-2015 12:56 PM
I would bet it has two parts: the mirror, and a detachable silver button that glues to the glass. You might post a picture, but there should be a release mechanism to separate the parts. Permatex makes a rear view mirror adhesive that I got at my FLAPS.
Good luck,
Dave
Tony V 10-03-2015 02:51 PM
A '76 should have the rear view mirror that uses the adhesive pad to adhere to the windshield. (unless it's been replaced with a later model) Get the black or dark grey pad as the white ones are really noticeable from the outside. Mark the location, on the outside of the windshield, and press the adhere.
Tony
grant lyon 10-03-2015 09:51 PM
+1 on two-part and PP has the Loctite flavor
37438-M258
Mirror Adhesive - Loctite Rearview Mirror Adhesive (.3 cc Kit)
Used on my sisters '84, easy.
Good price on Pelican.
MichaelUD 10-05-2015 08:36 PM
Good information to have.
My one year old grandson also loves to "drive" the 76 911S targa! Ha!
stormcrow 10-05-2015 09:25 PM
I'm sure superglue would work. However, you may not get it off if you have to replace the windshield. You can purchase adhesive at the auto parts store for rear view mirrors.
timmy2 10-05-2015 09:35 PM
I have the old trapezoid shaped glue on style on my car. Superglue let go in the sun.
I used a piece of 3m I-phone glass adhesive on it 4 years ago and it hasn't moved.
Razor blade will remove it.
For the old style the double sided adhesive pads Tony mentioned earlier is the way to go.
matt gineo 10-06-2015 05:10 AM
Tony
Thanks Tony, I found the pad on Pelican but it looks like they only have it in white. It says that it's a genuine Porsche part. I can't find any in black??
matt gineo 10-06-2015 05:11 AM
We have to teach them while they're young. He'll be driving me around in a few more years!
turbo owner 10-06-2015 05:20 AM
Glass shops around here would glue it back on for no charge, you might give one a call and ask.
matt gineo 10-06-2015 05:27 AM
good idea, will do. Thanks
Tony V 10-06-2015 08:11 AM
I had a glass shop install mine and it fell off the next day. They forgot to remove the remnants of the old glue pad that fits into the recess of the mount.
Sierra Madre sells the darker color pads.
Tony
matt gineo 10-06-2015 08:27 AM
Tony
Thanks Tony
jpnovak 10-06-2015 08:51 AM
Go to your local FLAPS. Get the black or gray 3M VHB tape. Cut two strips and place on mirror. Then stick to clean windshield. Won't come off.
The liquid adhesive just do not work well.
My son did the same thing a few times before I found the right stuff. Thanks to a good friend for showing me the tip.
