-   -   Removing windshield and rear window trim (http://forums.pelicanparts.com/porsche-911-technical-forum/885596-removing-windshield-rear-window-trim.html)
Shaun @ Tru6 10-03-2015 05:48 PM
I have found that a PVC pipe cutter cable saw is the best way to get the trim out of window rubber trim. Gently pry up a center connector, slip the cable under and saw away around the window. Trim pops out perfectly.
http://forums.pelicanparts.com/uploa...1443919649.jpg
http://forums.pelicanparts.com/uploa...1443919664.jpg
http://forums.pelicanparts.com/uploa...1443919674.jpg
timchar 10-03-2015 06:28 PM
Great idea thanks. Tim
Uwon 10-04-2015 06:30 AM
Shaun,
Did you need to lube as well?
Thanks for sharing.
Cheers,
Johan
Shaun @ Tru6 10-04-2015 08:26 AM
Hey Johan,
No lube needed, a light sawing action lifts the embedded channel out of the rubber molding if it's resistant to change.
wayner 10-04-2015 09:14 AM
Perfect solution. Thanks for sharing it.
I use the same technique using a long exact knife.
I cut the seal clean through to the other side not disturbing the trim.
-Thickest part of the seal remains on the car.
-The slice of rubber that you cut away from the main seal still holds the trim and can be lifted away from the car.
-the rubber that remains with the trim is so thin it easily will peal away without having to bend the trim.
It is a great technique. I hadn't thought of using a PVC pipe cutter cable saw.
Thanks for the tip Shaun
Wayne
sailchef 10-04-2015 10:28 AM
Nice job.
