Red face Help with connector? What is this?
I need some help with this one
I found this tucked away when i removed engine and gearbox.
Car from 79. The thing is located on left side of car, is a two wire, stretches as far as left rear shock absorber (but then its streched), looks like a connector of some sort.. But to what?
Help? Please 😢
putting the wrench AGAIN into the Grand Prix White ( however the condition is Everything but "grand prix" ),
-76 white targa, -79 silver targa, and in need of more garage space
Heja Sverige!
Old 10-03-2015, 07:10 AM
It looks like the sensor for the auto heat controller that goes into the "flapper box" that ducts heated air from the heat exchanger into the interior of the car. Look for it forward of the rear wheel, up high on the tub, under the car.
JR
Old 10-03-2015, 07:25 AM
Cant find any place to put it... So Guessing that PO or his workshop put in wrong flapper box on that side...
Now considering making a hillbilly solution, where should i drill the hole ?
Heja Sverige!
Old 10-03-2015, 07:55 AM
Thank you Javadog
I found pictures of how the rean flapper Box should look like and now know howto hillbilly fix it...
Will be better than having it tucked away behind the fuel lines....
Thanks again
Heja Sverige!
Old 10-03-2015, 08:13 AM
Old 10-03-2015, 08:19 AM
wrxnofx's Avatar
Javadog is correct. The sensor is riveted to the left flapper tube. It's item 14 from the PET. This is not the same as your model year PET, but it's similar I'm sure.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 10-04-2015, 11:34 AM
