Front seat and shifter issue
Hey guys I haven't investigated much into why the non-powered seats are doing this but my drivers side handle is stuck solid and both seats are just sliding freely front and back wondering if anyone has any initial thoughts of attack for me..
Also I've had the shifter removed and have re-installed it but the actually shifter turns on the spot like it's not knocked down all the way..does this need to be set in something like some sort of glue ? |
Member 911 Anonymous
Seats
Most likely the plastic holding clips under the seat have either dislodged or broken, it is connected to the 3-4 toothed lever that sits in the rails to lock the seats in place. An inexpensive part but a PITA to work under such small space. If you can, removing the seats will give you a better orientation of how the system works. Did you replace the crush sleeve, if not those are not re-usable, again an inexpensive part. You will still get some spinning but it will have to be intentional with some heavy twisting but for normal use the shift knob will stay in place. I do not recommend glue, it will destroy the knob in the future removal. Cheers, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Yes I dare say I will have to remove the seats...in regards to the shifter it's not the knob that's an issue its the rod itself that is spinning and being difficult when shifting into gears
Is your coupler clamp tight? I have lots of shifter parts and a couple spare couplers, let me know if you need anything. Might want to replace the two plastic bushings on the shift rod, cheap and easy to install.
I recently had my seats out to lube up my sliders and install a fire extinguisher mount. I did not see any plastic parts in the slider mechanism.
1982 911 Targa, 3.0L ROW with Webers |
if the shifter rod is rotating, the bonding between the upper rod and the lower may have failed.
I had to weld mine in place and I learned that the factory bonds the upper and lower rod together rather than welding.......at least on my 1973 What year is your 911?
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Fleabit peanut monkey
I am guessing the lifting arm shaft has corroded in the "hinge" right next to the part on the arm that engages with the seat runner teeth. Pull the seat. Look for the obvious broken or seized part.. It is a very simple mechanism. Try penetrating fluid for a few days to free up the shaft if that's what it looks like.
1981 911SC Targa |
I guess I misunderstood "handle is stuck solid" if it is rotating when you pull it.
1981 911SC Targa |
That's gold bob thanks I'll check it out ASAP
