-   -   Winter Storage Tip (http://forums.pelicanparts.com/porsche-911-technical-forum/885763-winter-storage-tip.html)
pampadori 10-08-2015 09:58 AM
I bought an old Honda motorcycle years ago that didn't run. I was gonna fix and flip since I had much success doing the same a few times before. This one kept fitting though. Had compression, spark, fuel. But still wouldn't run.
One day the bike fell over in the garage and I noticed some sunflower seeds emptied out of the baffle. 30 minutes later I had about 3 pounds of seeds on the floor from removing the muffler and beating on it with a rubber mallet.
Reinstalled the muffler and the bike ran flawlessly!
many a rodent have caused mechanical failures. Good for nothing creatures...
Otter74 10-08-2015 10:58 AM
This leads me to ask about what, in y'all's experience, are the most effective ways to keep mice and other critters out of the garage in winter. I don't seem to have any in the garage at home, but there clearly have been rats in the other one, based on the droppings. No problems found yet with the two (project) cars I keep in that one, but I'd like to keep it that way!
Lapkritis 10-08-2015 12:59 PM
I use multiple baited kill traps, deterrent spray in the shop and then quickcab bags inside the cars. Try to address their entry points to the building.
gomezoneill 10-08-2015 02:05 PM
Two cats solved all my problems no mice or chipmunks on 4 acres with a 2500 square foot garage.
IMR-Merlin 10-08-2015 02:29 PM
If you buy 3M electrical tape from any big box hardware store, then come in a plastic container.... perfect for covering this hole.
http://forums.pelicanparts.com/uploa...1444168364.jpg
IMR-Merlin 10-08-2015 02:30 PM
Also a few mothballs in the areas you suspect the critters are coming from will keep them away also.... or you could get a garage cat.
KTL 10-08-2015 02:59 PM
Thanks for the tip on the electrical tape container. Me gots one of those!
Shakin Joe here on Pelican also suggests this PVC "test cap" from the plumbing dept.
http://forums.pelicanparts.com/uploa...1218602283.jpg
whiz05403 10-08-2015 04:46 PM
Don't forget dryer sheets, I place 15-20 all over my 87 Targa in the winter and no critters. They hate the smell.
KTL 01-18-2017 10:03 AM
Since it's winter and another forum member recently discovered a rodent on top of his engine behind the fan, I figured i'd bump up this thread.
The little bit of effort required to keep your car free of rodents during the winter is worth it!
bdisco 01-18-2017 10:49 AM
CarBag - Protective Jackets for Storing Your Car or Motorcycle. Made in the USA.
I can attest to this product. ^
KNS 01-18-2017 06:27 PM
I've mentioned this before but I use unscented glue traps. I found one or two mice initially but very rare to find one these days.
A guy at a pest control place recommended unscented glue trap versus the scented or baited because you don't want to attract them.
faverymi 01-18-2017 07:07 PM
Peppermint oil.
Learned this from a farmer.
It works. Very well
Otter74 01-19-2017 01:27 PM
How, or where, do you apply it?
Originally Posted by faverymi (Post 9438218)
Peppermint oil.
It works. Very well
RSBob 01-19-2017 02:15 PM
When storing or sitting for extended periods, always keep your heater levers up to help keep mice out of your heater system and cabin
Snitzler 01-19-2017 04:22 PM
The rubber plug came from the plumbing dept. at Home Depot, fits perfect and bonded on with RTV. The blank off plate was templated off of the a/c "thing" and made from some spare aluminum and painted.
http://forums.pelicanparts.com/uploa...1484871718.JPG
pete3799 01-19-2017 04:40 PM
Behind there ears:D
Noel 01-20-2017 09:07 AM
Just last weekend I was changing my spark plugs and noticed debris in the back of the passenger side engine bay in a small hole above the on engine oil cooler. After digging with my fingers for 15 minutes, this is what I pulled out. Have to remove the fan to check the tops of the cylinder fins now.http://forums.pelicanparts.com/uploa...1484932010.jpg
Brorag 01-26-2017 03:15 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/940876-mice.html#post9414265
RMR73 01-27-2017 06:02 AM
With the peppermint oil on cotton balls inside a perforated plastic container . Smells much better than mothballs !
wrxnofx 01-27-2017 07:35 AM
So do most people. Those things are as bad smelling as mothballs.
