-   -   908 ~ MoTec start-up file for 3.6 needed (http://forums.pelicanparts.com/porsche-911-technical-forum/885917-908-motec-start-up-file-3-6-needed.html)
Spydermon 10-06-2015 11:40 AM
Hello,
I need a start-up file for a 3.6, twin-plug, twin distributor, 60 minus 2 flywheel with a Motec 84M.
If you have one, please reply. I need it to start-up our new WerkzCars 908 Spyder replica ...
Randy
http://forums.pelicanparts.com/uploa...1444156603.jpg
http://forums.pelicanparts.com/uploa...1444156625.jpg
jpnovak 10-06-2015 12:29 PM
Can't give you a Motec file but you have to post the build file on this car. I can't imagine a 3.6 in a light tube frame, fiberglass body creation such as this. That looks like so much fun at the track.
jrhb 10-06-2015 01:10 PM
You could try posting over at the Motec forums http://www.motec.com/forum/.
It's never worked for me personally, but you never know things may have changed.
Spydermon 10-06-2015 01:42 PM
I'll try that too, thanks.
Spydermon 10-07-2015 04:18 PM
Nope, nothing I can use on the Motec website.
Does anybody have a start-up file for a Porsche 964/993 engine with Motec M84?
scarceller 10-07-2015 04:28 PM
Every Motec install can vary, it's going to be hard to find a exact file for that engine. Sometimes with Motec they do Speed Density (MAP Based) and sometimes they do TPS (Throttle Position) based fueling. And even if you know what they are using the TPS and/or MAP device could be different from other tunes. Then you also have IAT and Baro sensors and these can also vary.
Did that motor ever actually run with Motec? and do you know who tuned it?
Your best bet is to try finding out who in your area is Motec certified tuner.
Impressive looking motor, someone spent some money!
group911@aol.co 10-07-2015 08:42 PM
I have the file from a 993 RSR but it's M48 based
911Freak 10-07-2015 09:33 PM
Call Ed Pink Racing....
RSstop 10-09-2015 07:00 PM
Hey Randy,
Just saw this. I should have a M84 file for 3.6 and a 3.8 if you still need it.
Lyn
