Cht sensor measurement.
I'm not an expert, but the 2nd wire on the newer sensor is just a direct ground. So your single wire is prolly quite old and that reading is out of range. They can be a bugger to replace so you should do a search and see how it's done.
I have the SST for install if you need it Dr Gerry.
What are the symptoms 86? The reason I ask is that my 86 (as well) has an RPM needle that drops faster when cold than warmer, so I am thinking the CHT may be playing a part in this.
Serge |
LOL, can't remember anymore, several of you Pelicans have my tools :D One day I will get around collect them I guess.
| All times are GMT -8. The time now is 02:38 PM. |
