-   -   Sending the 73 to the crusher (http://forums.pelicanparts.com/porsche-911-technical-forum/886162-sending-73-crusher.html)
jsoderbe 10-12-2015 10:06 PM
Are you sure the sound is from inside the engine? It just seems strange that this happens hours after pulling the engine and fixing the clutch fork. Something loose in the clutch package maybe?
Just saying that the timing suggests it should be interconnected....
Regards,
Johan
wayner 10-13-2015 04:32 AM
;)http://forums.pelicanparts.com/uploa...1444701695.jpg
Such a proud and so devastatingly fast engine looking like such sad mess right now.
At least this will give me a chance to upgrade my oil catch can.:D
GomezOneill, Puddy, UncleBilly, 911T70, Berk, T77911S. Steve, Bergo, Sammyg2, Craig, Florio, DanielDudley, Timk, bpu699, Graham, Dodgeman, Jamie, Hary, Gary, Jim, Tim thanks for the moral support at a time when I needed it most. Who knew I had so many friends.
Thanks to you guys, I'm back in the saddle.
Although these guys were a little more direct with their tough love. THer's no crying in baseball! ;)
Originally Posted by Steve F (Post 8827450)
Originally Posted by Dpmulvan (Post 8827738)
Tear back into it and fix it!!!!
You guys are just too practical.
Up next is this plan
Originally Posted by Jim2 (Post 8833692)
I listened to your video a couple days ago, no doubt coming apart but...
Have you pulled the plugs to see if it ingested something? Electrode will be hammered.
Remove sump plate to see if any material is visible
Remove oil filter and cut open to inspect for particulate.
Regards,
Johan
Johan, that is a good thought.
I haven't ruled out a clutch issue, but the sound doesn't seem to be coming from that area.
In addition, I had driven over 300 miles the night of the clutch throwout bearing replacement.
I would expect that if I was to experience a problem related to that, it would have shown up a bit sooner, but clutch sounds inexpensive so fingers crossed. Either way, the engine has to come out.
OPTIMISTIC CAUSES (in order of pain):
1)S̶o̶m̶e̶t̶h̶i̶n̶g̶ ̶r̶e̶l̶a̶t̶e̶d̶ ̶t̶o̶ ̶t̶h̶e̶ ̶f̶a̶n̶ ̶b̶e̶l̶t̶ ̶o̶r̶ ̶a̶l̶t̶e̶r̶n̶a̶t̶o̶r̶ ̶t̶h̶a̶t̶ ̶I̶ ̶h̶a̶d̶ ̶r̶e̶c̶e̶n̶t̶l̶y̶ ̶r̶e̶p̶l̶a̶c̶e̶d̶
2) Something related to the clutch throwout bearing that had recently been replaced 300 miles ago?
3) Something in the top end, maybe part of the valve train?
4) Piston related?
5) Rod related?
6) Crankshaft related?
gomezoneill 10-14-2015 04:53 AM
Maybe a rocker arm shaft loosened up and the rocker is being knocked around. I'd pull the valve covers and spark plugs before anything else.
wayner 01-19-2016 06:15 AM
Autopsy results and rebuild thread continued here:
(Feel free to join in on that thread)
http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html#post8963557
This thread is closed. On to happier times!
