carbon fiber tail light housings
I have noticed the increasing popularity with LED bulbs especially for the 911 since they are so hard to see. I have built a bunch more of the housings for a customer and have quite a few sets left over. If anyone is interested in supplying any of the LED systems that have been developed in these forums I would be able to mount into the carbon housings and provide a turn key part. depending on mounting solution around $250 each seems fair plus the LEDs
$250 per pair or per side?
1986 3.2 Carrera |
per side
What would be the price for just the housing without the wiring?
wow do want
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
The wiring pictured actually comes with the LED
What I am offering is ability to modify the housing for the lighting option and provide a turn key part for example The part pictured a for a race application with only brake lights needed I have make part that uses stock bulbs and wire harness and inside of housing surface finished in reflective surface Most of the cost is the time and materials to laminate and vacuum bag the housing Last edited by dsfnctn; 10-13-2015 at 09:55 AM.. |
