Senior Member
CIS washer and gasket PNs
Does anyone have a good list of part numbers for all the CIS gaskets and washers I should replace while using a pressure tester on the various CIS components (82 SC)?
I would like to replace the injector o-rings if I do a pattern test, and I think I can find that one, but I am having trouble getting part numbers for the ones at other points in the system, like the WUR, cold start injector, etc. Thanks in advance, Olivier
Olivier Hecht 1982 911SC |
Senior Member
btt for the evening rush...
