-   -   Who makes rebuild kits (http://forums.pelicanparts.com/porsche-911-technical-forum/88699-who-makes-rebuild-kits.html)
crashr 11-25-2002 12:25 PM
Can someone tell me some different companies that make rebuild kits. Which ones are good, which are not. What is a reasonable price for one? Any info would be great. I know of motor meister and ebsracing (it seems ebsracing.com link is gone???)
Jbabic 11-25-2002 01:09 PM
I got all mine from Pelican, plus they do a bang up job on tech advice.....to me it was worth it!!!!..
as far as a machine shop, I have no advice...I am in Ohio.
john walker's workshop 11-25-2002 01:14 PM
i'm sure that pelican can put together a "kit" for you. all "kits" may not be created equally. find out what you get from those kit suppliers, and what the brand names are, and then compare.
Wayne 962 11-25-2002 01:18 PM
Kits are inevitably a bad idea, as you generally get parts that you don't need, and don't get some parts that you do need. We have everything that you need, and can customize a package for you, often at less than a 'kit' would cost. This is because you're not paying for something you don't need.
We will be offering kits in the near future, but they will be highly specialized bundles (or lists) that will be based upon what you actually need. Like a bottom-end kit, a top-end kit, and an injection kit.
-Wayne
crashr 11-25-2002 01:37 PM
So I guess what your saying is that I should wait to order the individual parts that I need until I have everything completly dismantled. I looked at the list of parts that motor meister has and it seems quite exstensive. This is the list they give.
Motor top end "Re-Ring" Rebuild Kits
2 – Timing chains (Link style)
* German Iwis
1 - Set Turbo chain rails
* German Swag
12 - Bronze phos. Valve guides
* Longer lasting
* Better lubrication
* Harder material
12 – Piston pin clips
* Factory Porsche
* Never reused
8 - Oil return tube seals
* Green Viton
2 - Cam pins
* Factory Porsche
2 - Valve cover gaskets lower
* Reinz
2 - Cam end play gaskets
* Reinz
Cam plate O'rings
* Reinz
* 1 - oil thermostat O'ring
* Reinz
2 - Cam housing gaskets
2 -Cam shaft cover plate gaskets
* Reinz
6 - Exhaust gaskets
* Reinz
6 - Intake gaskets
* Reinz
12 - Teflon valve stem seals
* Longer lasting
1 Complete set of rings
* For Mahle or Kolben Shimdt
* Comes with special break in tips
2 Cam shaft key ways
* Factory Porsche
2 Camshaft pins
* Factory Porsche
6 Head copper shims
* Different thickness
2 Valve cover gaskets upper
* Reinz
1 Set of crush washers 6mm & 8mm
* Wurth
1 Set of lock nuts 6mm & 8mm
* Wurth
6 Cam line seals
* Reinz
2 Cam housing to case gaskets
* Reinz
6 Intake gaskets
* Reinz
6 Cylinder shims
* Reinz
Misc. gaskets, O'rings and seals included (all Reinz) made in Germany
Prices:
Porsche 2.0 - 2.7 . . . . . . . . $599
Are you saying that more that likely I won't need alot of these parts. I will obviously need an entire engine gasket set, and I would think that rings are an essential as well. Don't gasket sets alone cost nearly $500?
emcon5 11-25-2002 01:41 PM
For what it is worth, I would pound my balls flat with a wooden mallet before I bought anything from MM.
Too many horror stories.
Tom
sithot 11-25-2002 01:52 PM
Wayne is correct about kits. You will inevitably be short on something and long on something else. Take care to make sure everything is compatible as well.
I suspect Wayne can help with that.
crashr 11-25-2002 02:04 PM
As a newbie to this bb could you please sugest the best brand of wooden mallet :o
I suspect my car to have a blown exaust valve. If this is about the maximum extent of the damage.. could someone give me a guesstamite of what it will cost me in engine rebuild parts.
silverc4s 11-25-2002 03:02 PM
Exactly what do you mean by "blown" exhaust valve? Do you have zero compression on one cylinder only? Does your engine still turn over? Is the valve bent? broken? What about the piston? cylinder? How many miles on the engine. Just WHAT WERE YOU DOING when you "blew" this valve? and so on..
Tell us more details, and we can be more help. Friends don't let friends do MM...:cool:
Wayne 962 11-25-2002 03:29 PM
For example, in the kit that you just mentioned, they include rings for KS cylinders - there are no such rings for Alusil cylinders - only Nikasil. You can use the Nik rings on the Alusil cyls, but there's a 50-50 chance you'll have to tear apart your engine again (not good).
Also valve guides? Who installs their own valve guides? The machine shop will do this.
This seems to be standard gasket set with some guides and rings tossed in. In the near future (if you can wait that long), I will have extensive kits for rebuilding that will directly follow along side of the new engine rebuild book...
-Wayne
dtw 11-25-2002 04:12 PM
That list/pricing is nothing to shout about. You should be able to do better at Pelican or race shops who turn over a high volume of these parts and aren't completely FOS. I wouldn't even buy muffler bearings from MM.
Superman 11-25-2002 04:20 PM
Ouch! That hurt just reading about it.
Wayne's advice seems very good. I think the Pelican folks can help you figure out which gaskets and parts you will need, so just buy those parts. Once in there, you will surely find a need for some things you had not planned. Engine rebuild jobs take more than a day or two, so you may end up with more than enough time to assemble parts.
john walker's workshop 11-25-2002 04:45 PM
i didn't see any valves in that top end list. or sprockets, or idler supports, or cam oil lines, or tensioners, or head gasket o rings, (the copper ones are cylinder base gaskets), or muffler gaskets. see what i mean. there's really no "kit", you teardown and order what you need, over and above the gasket set. and no, the gasket set is not $500. way less.
sithot 11-25-2002 04:46 PM
Kolbenschmidt! I was so happy when I found out they were producing pistons (in their own plant) for the vintage BMW mc's.
There was a time when all you could get were Italian made pistons that didn't expand quite right. Seized engines were the order of the day unless you made the tolerances sloppy. Then you got slap until they warmed up. Real nice.
Jbabic 11-25-2002 06:19 PM
I DID POUND MY BALLS AFTER SEEING WHAT MM DID TO AN ENGINE AND THE PRICE THEY WANTED AFTER THIER AGREED TO QUOTE!!!!
Doug Zielke 11-25-2002 08:11 PM
Mainly because I wanted to spend the PCA $100 certificate, I ordered the genuine Porsche top-end gasket set (P# 930 100 907 03) from my local stealer.
While I have absolutely no complaints about the quality of the set (and the price was not that bad either), there are some things in it I will not use (CIS parts??), and other things I thought should have been included, that were not. Maybe "kits" are not such a great idea after-all.
john70t 11-26-2002 02:48 AM
"As a newbie to this BB could you please sugest the best brand of wooden mallet "
Never having any experience with the company itself (thanks again and again to the free exchange of information!!), I would not buy anything from a company with a a repeat history of flagrantly ethically and legally screwing of the customer.
Perhaps the Motor Meister board would provide you with that information :- )
