Oil level
What is the trur amount of oil for the 911 engine.I own a 914-6,It holds ten quarts.My brother ownes a 73 911E and I think it holds ten quarts.How ever the 101 projectsd book states that it holds twelve quarts.
I'M confuzed.
Old 11-25-2002, 05:08 PM
I think when you change the oil you will use about 10 quarts. Drain the oil lines and coolers and you get about 11 quarts.
Old 11-25-2002, 05:15 PM
BER BER is offline
BER's Avatar
Porsche Crest
I think what is confusing you is the total oil capacity of your engine vs. the refill quantity at an oil change.
For example, my 3.2 liter engine's capacity is 13 quarts, but at an oil change I can only add about 10 quarts. If I was rebuilding my engine, I would add 13 quarts to refill the system.
Most 911 engines have residual oil (2 or 3 qts.) in engine after you have drained the tank and sump at an oil change.
Bruce
Old 11-25-2002, 05:17 PM
tip the car on end and you'll get 2 more. bone dry, the system usually will take 12 easy. but they're never bone dry unless the engine is new.
206 637 4071
Old 11-25-2002, 05:18 PM
The engine in question is the 73 and is a brand new rebuild
Hey John,I got some old bus parts.
Old 11-25-2002, 05:22 PM
e/mail me about the bus parts. jwworkshop@aol.com thanks.
206 637 4071
Old 11-25-2002, 06:20 PM
