Dry break /quick change fittings for AN18-AN20 SS hose?
hi peeps,
does anyone know where (or if available ) dry break SS hose couplers in large size hose ?
i am running AN20 hose for feed , and AN18 return oil lines
I have been swapping out motors and gearboxes in my race car so frequently that it would be great to have the oil feed and return lines ( I have front mounted oil tank) with these type fittings... like Staubli, or Quik Fit. This would negate the gawd awful oil messiness draining both tank and case and lines everytime..
However it seems they are only, readily avaliable in small sizes for fuel , clutch hydraulics etc.
I already assume they will be mega $$ if one can find them.
The NASCAR boys must have solved this long ago as they used to swap in motors just for a few qualifying laps...
Any help would be greatly appreciated.
Thanks Frank
Old 10-16-2015, 12:33 AM
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pct_472512.pdf
Page 8 Should be available at good hydraulic shop
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-16-2015, 03:58 AM
Jiffy-tite Motorsports | Global Leader for Quick Connect / Quick Disconnect Fluid Fittings
you will want the 3000 series as it fits a -12 line. you can also buy them on summit.
Old 10-16-2015, 04:26 AM
thanks dan this is perfect best wishes frank
Old 10-16-2015, 11:27 PM
