87 930 starting problems
Cold or warmed up, about 60% of the time having starting problems. Starts to fire and runs on what sounds like 2 cylinders. When you give it some gas is picks up to 4 cylinders for 5 to 10 seconds then hits on all 6. Once it is running, it runs great, but the start up is pretty embarrassing! Any DIY ideas???
the state of the tuneup, no cold start valve function, fuel pressure bleed-down due to leaking check valve, leaking injectors, a warm-up regulator starting out too lean, and various other things can cause that. do a search for "hot start", and see what comes up.
