-   -   No right rear turn signal but works with hazard! (http://forums.pelicanparts.com/porsche-911-technical-forum/88842-no-right-rear-turn-signal-but-works-hazard.html)
keitho64 11-26-2002 12:32 PM
I just installed the new turn signal flasher and I can now flash. :D However, the passenger side rear turn signal does not flash when the switch is set for the right turn. The front right signal blinks but not the rear. If I turn on the four-way flashers all four signals blink. I should add that all taillights are fine as are the brake lights.
I am confused as to why the hazard flashers light/blink the right rear light but not the right turn switch. Does anyone have an idea? I doubt it is a problem at the light since it is only a right turn signal problem, if the four-way flasher did not light/blink I would look at the socket. Could there be a problem at the turn signal switch? This has me stumped.
ccandgc 11-26-2002 03:30 PM
Wouldnt the 4 ways channel thru the sig switch anyway? Pull the lense off the tail lite, and while you have the R turn flashing, give the bulb a little juggle/twist, etc. Maybe that'll help!
keitho64 11-27-2002 06:43 AM
Unfortunately it is not the bulb. I have a 12-volt signal at the socket when the 4-way flasher is on but not when the turn signal is on. This seems like it should be simple and I think I am missing something. I am going to tear into this tonight and see what I can find.
