Slumlord
Is there a super thin Porsche wrench for the bolt heads in the back of the adjustable spring plates? I have installed my 'new' spring plates, and I'm having trouble tightening up the nuts.
PH |
yes. check in the pelican parts online catalog under tools.http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_suspen_main.htm . then go to page 13 . MAX
Formerly bb80sc
I went to my local bike shop and purchased two for 13.00 each. They are 36mm and used for adjusting the head set. I have two, one by Park, the other by Pedros, which I like better. It has an offset head and a nice coated handle. They only bummer is that you do not get the 24mm you need for the other nut. I was able to use the wrench from one of my power saws, worked great. The 36mm ones work great on the oil lines as well!
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited Last edited by Vipergrün; 11-26-2002 at 03:41 PM.. |
