Rear wiper help Needed
I an trying to wire up a rear wiper motor to the switch in the frt.
I can find all sorts of wiring diagrams for the 84 and up models but nothing for an 83 and down. My Frt. Switch has 3 poles not four like the later models does anyone have that section of the wiring harness or can pull their switch down and post or send me a picture? edit ...... the right switch has four tiny connectors Thanks Lorne M. |
I went back to 1975 and still found a four pole switch.
53 red/black to fuse 14 53a red/black to motor 31 brown 31b brown/white to the motor in the rear That's the only mention of it I find in the factory wiring diagrams that I have. JR |
I would still like to see a picture of someone's rear wiper switch pulled down to see where the wires actually go.
Anyone Thanks Lorne M. |
Wiper switch
Hi, Lorne, does your switch have the following terminals ?
31B 53A 31 53 |
No my switch only has three tabs the fourth is jumpered to one tab on the same side.
Lorne M. |
Am I correct to assume that Porsche doesn't pre-wire the rear wiper switch behind the dashboard?
Thanks |
yes, I haven't found any cars so far with the extra wires.
I have had two fellows here makes but the two harnesses needed so that mine would look original. if you have a/c then the rear condenser has a cut out section Lorne M |
| All times are GMT -8. The time now is 08:33 PM. |
