help: seat belt recoils locked
Hi - I have a few rear sear Repa recoilers that are locked somehow. When I tug on the belt they won't draw out. Is there a trick? I've tried to set the recoiler on a level surface and hold it at different angles. is there a release or reset button someplace?
'69 911E Targa
'87 Carerra Coupe
Old 10-29-2015, 10:06 PM
Try holding it in the position that it would be in when installed in the car-it should release then.
Old 10-30-2015, 04:36 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Actually, I found that I could not even hold it at the correct angle by hand, rather it required being being lined up with the mounting holes in the car in order for the belt to release. Pretty interesting little piece of engineering.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 10-30-2015, 05:40 PM
wayne robson's Avatar
The other way most times this works,you pull on the belt really hard i mean
100 ibs plus slowly and strong , then release the belt very slowly then it usually works.
Old 10-30-2015, 05:54 PM
I thought the same with mine but when mounted they work fine.
78 911 st backdate
87 944
00 996
Old 10-31-2015, 09:17 AM
gptom's Avatar
try holding the belt vertically. That's the position the inertia reel wants to release
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 10-31-2015, 12:04 PM
Thanks everyone. I got them mounted and they are working great.
'69 911E Targa
'87 Carerra Coupe
Old 10-31-2015, 10:30 PM
'69 911E Targa
'87 Carerra Coupe
Old 10-31-2015, 10:32 PM
