non-whiner
mreid's Avatar
What is unique about the 1978 flywheel?
I bought a light steel flywheel for my 78 3.0. When I opened it up, there was no provision for the pilot bearing. I then noticed that the 78 is listed in pelican as unique, but there is no picture to check out the pilot bearing. Is the 78 crank different? It is a 9 bolt, but the crank looks too small to house the pilot bearing. Any ideas?
"Too much is just enough."
Old 10-31-2015, 03:15 PM
they just use the same old pilot bearing as the 77 and earlier. The later ones had a wide flange bearing that attached to the crankshaft with 3 bolts.
206 637 4071
Old 10-31-2015, 03:24 PM
non-whiner
mreid's Avatar
Ah, that explains it. Thanks, John. The flywheel I have has a large opening, but my crank doesn't have the three bolt holes. I'll order the 78 version and it should have the small opening that the pilot presses into. Always something!
Old 10-31-2015, 04:14 PM
In a pinch, you can use that flywheel by tig welding the big pilot bearing in place. 3 or 4 spot welds holds it nicely.
206 637 4071
Old 10-31-2015, 05:04 PM
