-   -   Stock front sway bar removal? (http://forums.pelicanparts.com/porsche-911-technical-forum/889238-stock-front-sway-bar-removal.html)
Tom '74 911 10-31-2015 02:26 PM
I haven't worked with a stock front sway bar before so I want to make sure I'm on the right track. This is a '69 912 which I'm sure has been untouched for quite some time.
Should I be able to slide the bracket/cover over the rubber bushing and over the end of the bar? I trimmed off the rubber a bit but to see if I could get it started, but it's not budging (yet).
I just wanted to be sure there isn't an easier way.
Thanks for the help.
Tom
http://forums.pelicanparts.com/uploa...1446330318.jpg
