H-4 mystery (for me)?
Morning guys,
I got a little surprise this morning when I pulled the trim ring on my H-4 to effect a rubber seal change. I found another trim ring underneath, this one chrome? Further, the phillips screw in the 2 o'clock position simply turns either way with no apparent stop. Is this an adjustment screw? How do I remove the headlight, the screw at 6 o'clock is already out? Is the chrome trim ring loose too and just pressure fixed? Thanks, Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
The chrome ring is part of the headlight assembly. The screws at 2:00 and 8:00 are adjustment screws for aiming the headlight. The headlight is supposed to be held in with a screw at 6:00 and the trim ring is held in with a second screw at 6:00, that screws into the center of the first screw. If you have only one screw holding everything in, your light is installed incorrectly. Once the screw at 6:00 is out, pull the bottom of the light down and forward, then rotate the whole assembly up to release it from the lip on the top.
JR |
Thanks JR
