carrerarsr65
911 valve adjust.
just got done doing valves. some are still to loose,can i get away with just draining crankcase oil,and not the tank ,seeing the oil only has 5 mins. on it. thanks al from mass.
You can do them one side at a time by jacking up first one side then the other. I used a lid from a plastic storage container to catch oil (even put a drain hose on it, which wasn't necessary). Get it up as high as you can, let sit for a half hour or so to drain out of the cam housing.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
How loose are we talking? Better a little loose than too tight. Most of the Guru's will tell you that the clearance becomes tighter with miles and often a freshly adjusted engine makes the most noise.....until the next adjustment. Cheers
Post above is true. After I adjusted my valves my car sounded like a 67 bug. But after a few thousand miles, it sounds like a 73 bug. Much better.
Most of the valves I adjust are looser than .004. Don't find tight ones much.
Not to hijack, but - I have about 1,000 miles on a complete rebuild and the ticking drives me crazy. Things were gone back through after the engine dyno. Should I check the gap, or just leave them for a while? Car runs great and is very strong, just very (I think) noisy.
Todd
'81 SC |
Fleabit peanut monkey
Lose a little oil then replace. No biggie. Don't change it. WHY is there a fat gap? You need to ask yourself this question. What did you NOT do when performing this procedure? You did spin the crank a couple of times and re-check right? Every single valve? If you did not, there is your problem. You did not perform due diligence on a critical operating parameter on a $6k engine. Why the eff not? Think how much time this saved you.............. Like negative six hours. You get to do it again. Next time, read, suck it up and do it correctly. Call me a prick, but do it right from now on. The effort will serve you well. Like the car without side skirts.
1981 911SC Targa Last edited by Bob Kontak; 11-01-2015 at 04:34 PM.. |
Brew Master
I recently raised the right side, adjusted valves then raised the left and adjusted them. It take a bit of time but if you don't want to lose all the oil it's worth it.
If you had rockers re-bushed and the faces ground, new cam, blah blah, the interface should be re-set at 1,000 miles.
1981 911SC Targa |
Thanks Bob. Yes, different cams, rockers refaced, etc. I'll go ahead and check, adjust as needed.
Thanks! Todd
'81 SC |
FWIW, Just put that in your hip pocket. Glad to help anytime I can.
1981 911SC Targa |
Thanks Bob I'll keep that in mind. I'm over in Denver, so not that far from Gastonia. I was thinking of picking up the feeler gauge and the Kirk tool.
Todd
'81 SC |
carrerarsr65
thanks bob for being so suttle,well said my porsche brother!!
Got a bit of a shock when I saw your car; thought it was mine! Don't get many in minerva blue. Here's mine for comparison
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Hey John are you saying that the valve train loosens with miles? If it does, presumably the slack is being created by wear on cam lobes and rockers.....and not tightening with the valve sinking slightly into the head between adjustments.....like I have read on this board. Personally I can't say, since I loosen off adjusters before adjusting down to .0004, I never could weasel the feeler into an adjusted gap without destroying feelers at an alarming rate. My freshly adjusted 85 does have one of the noisiest valve trains (at idle) in the known universe, my 993 with hydraulic lifters is Rolls Royce quiet by comparison. When I adjust valves, I adjust and readjust until a slight tugging is felt on the feeler when you try to move it about. If the feeler falls out when tightening the lock nut....back to square one. John, a ruling on this issue(loosening/tightening with miles) be good, LOL.
i have pulled the lower valve cover without draining or jacking the car on one side. not a lot came out.
