nick-moss's Avatar
Leland Pate's engine photo album
Leland
Congratulations, a very educational site, with some high quality images.
You had the cases etc. "hot tanked", is there a more technical description of this process so that I can find someone in the UK to carry it out on my stripped 2.8?
Nick Moss - RGruppe #318
early911.co.uk
Old 11-27-2002, 07:19 AM
Senior Member
Leland Pate's Avatar
Hey Nick,
I would think that you could find a place to hot tank your case halves, cam towers, heads etc.
You just need to find a shop that has a hot tank for "ALUMINUM". Or Al-u-mineum... or howevery you guys say it.
There are hot tanks that are built for iron which can melt/damage aluminum parts.
So, after you make sure that the tank is designed for aluminum, your good to go.
Another thing... make absolutely sure that you have removed all gaskets and o-rings before having the parts dipped. They will melt.
Oh, and another thing... remove the two oil pressure by-pass springs and plungers from the case halves before being dipped too... they can get real stuck!
I can't give you any specific places in the UK to look up... might try a couple parts stores or a good engine rebuilding shop.
Also, you may find some helpful information in this Tech Article that I wrote last year detailing my engine rebuild.
http://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild1.htm
Glad to hear that the picture gallery was of some help to you.
Chief Architect and Mastermind,
SCWDP
Old 11-27-2002, 08:51 AM
Senior Member
Superman's Avatar
Your 2.8 case is probably magnesium.
Mocha 1978 911SC. "Coco"
Old 11-27-2002, 09:04 AM
nick-moss's Avatar
Superman you are absolutely right|
That might have been an expensive mistake.
Hot tank for magnesium OK?
Leland: A-L-U-M-I-N-I-U-M
early911.co.uk
Old 11-27-2002, 09:10 AM
Senior Member
Hmmm... good point... I have no idea if aluminum hot tanks are ok for Mag parts.
Good catch, Jim.
SCWDP
Old 11-27-2002, 09:12 AM
CamB's Avatar
http://www.world-aluminium.org/history/language.html
Hehe - you're both right.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 11-27-2002, 01:37 PM
