Targa owners: install rear beading without glass/trim removal?
Hi all,
The lower beading on my targa window is cracked in a few places. This is the one that goes around the base of the glass, along with the aluminum trim (tucked under, I gather), past the engine compartment. I replaced the top one already, that was easy. I'm thinking about trying to replace it for appearance and water-tightness, but don't want to go through the whole adventure of removing the rear glass. Is it possible to lift the trim oh-so-gently and tuck the new beading underneath it? Has anyone accomplished this feat? It's the piece with the red arrow pointing to it in this pic:
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Anyone?
Russ
Looks like nobody will touch this one. I've heard it can be a nightmare working with the glass. I to own a targa and would like to know if it's possible...
R |
Eva
I was just pondering this over the last few months. My situation being different where I don't have any beading, and only learned this in inspecting other cars.
When the PO had the car sprayed, apparently the body guy decided to just leave it out... I may yank my glass in time because I have a Singer-esqu detail I want to complete on the stainless bar cover that I've yet to see executed on any Targa
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Fleabit peanut monkey
Have you tried getting to the screws with everything is place?
I think it can be done. How flexible is your main window rubber?
1981 911SC Targa |
I have my rear window out I don't think its possible replace without removing everything.
Garage dweller
Pretty sure you can replace with glass in place - just been so long since i've messed with it I can't remember. I will go take a look at my car later today - maybe this will jog my memory.
Don Sjolin IIIEURO AUTOWERKS 616.874.7932 |
I think that goes in with the main glass out
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
grateful user
Yes, glass must come out, which is not all that bad with help. Could be a spot of rust that needs attention there to, always is in that area. Get the oem weatherstrip, if you still can, the aftermarket one is junk, dont even attempt to use it. Be careful of the press in beading, bends real easy.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Couple of fasteners in the wheel well. That said, I have never done it and there is risk. I can see the metal strips in the rubber bending when gaining access, then you are screwed.
1981 911SC Targa |
