-   -   Trailing arms help (http://forums.pelicanparts.com/porsche-911-technical-forum/889866-trailing-arms-help.html)
winders 11-05-2015 02:51 PM
Frank,
According the folks at Jerry Woods Enterprises, the spring plate mount gives you a more linear and more appropriate motion ratio as the suspension moves. In other words, mounting to the spring plate is better than mounting to the trailing arm.
mreid 11-05-2015 05:20 PM
The sway bar mounts to the spring plate by replacing the eccentric adjuster with an eccentric bolt as shown in this diagram:
http://elephantracing.com/documents/911%20Rear%20Swaybar.pdf
Flieger 11-05-2015 06:43 PM
I've got some new Tarett 22mm RSR style bars available in case it helps you. The rear is an early bolt spacing. Bought them but decided not to use them.
frankc 11-05-2015 08:18 PM
I wonder if this is assuming an aftermarket adjustable bar vs. the OEM bar. One other aspect I didn't care for on some of the spring plate mounts that I've seen is that the distance between the spring plate and the drop link is quite long, resulting in a cantilevered geometry. Obviously it must be ok as I haven't heard of these fasteners failing, but it just looked stressed to me.
There was a bit of discussion a while back on the drop-link topic as well:
http://forums.pelicanparts.com/porsche-911-technical-forum/713360-adjustable-rear-drop-link-attachment.html
winders 11-05-2015 11:35 PM
Well, the whole point of fasteners is survive stress. As long as the fasteners are strong enough all is fine. Plus, the geometry is otherwise quite a bit better with the spring plate mount versus the trailing arm mount.
I use Tarett sway bars on my race car. I have to use the trailing arm mount because of the raised spring plate front (chassis) mount on my car. The drop links would run into the frame rails if I used spring plate mounts. I had to get custom drop links from Tarett and mess around with spacers to get everything setup so the heim joints would not bind. I would have had no issues if I could have used the spring plate mounts.
RSTarga 11-06-2015 11:51 AM
Don't the aluminum trailing arms have a different shock angle than the 70 steel ones? I think they may require some machining there too. There are clearance issues at the top shock mount.
78-911SC 11-06-2015 01:52 PM
You are correct RSTarga. Go to post #20 and it explains how to go about achieving the proper angle and clearance. There are a couple ways to do it and I plan on doing the one that requires removing 1".
