Help cylinder Not working
Hello friends have a 86 911 carrera Cylinder
4 &5 spark plugs are turning black. Replace the rotor, cap, spark plugs twice Had all the fuel injectors cleaned by a shop. When you start the car it sounds Like When you remove a spark Wire. Shaking When is running
Car was running fine When I parked in the garage I removed the fuel tank cleaned it out and that's when it started happening. Please help what should I do Hope I explain it well
P.s car was sitting for 8 mouths Before I cleaned the gas tank out
Old 04-13-2023, 05:32 PM
kevbo's Avatar
Double check all your vacuum lines, especially the ones on the fuel regulator
Kevin
1986 Carrera Targa
Old 04-13-2023, 06:43 PM
Not sure what the order is that you did everything, but how long until you had injectors cleaned and then installed. 4 & 5 are black so running rich. I would move injectors 4 & 5 to other side and see if it follows. They could be stuck open. Are all wires fully connected. Did you touch the valves? Did you replace the filter?
Old 04-13-2023, 07:40 PM
Also the vacuum lines going to the regulator and damper make sure no fuel is in them. That was my issue and it was dumping fuel.
Yes all vacuum lines are connected and securedid not see any fuel on the lines but Going to double checking again The regulator
Thank you
Old 04-14-2023, 03:20 AM
Injectors were clean and put back on the vehicle of the same day. The shop told me they were Working good. All wires are fully connected. The valves were never touched or engine open. Fuel filter was replaced Thank you
Old 04-14-2023, 03:24 AM
Going to double check today thank you.
Old 04-14-2023, 03:25 AM
Schulisco's Avatar
Check the spark plug wires. Probably they're gone bad over the time. The spark can jump over a break, but with every break it's going weaker up to a complete fail.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-14-2023, 03:41 AM
Yes sir I replaced the wires as well thank you
Old 04-14-2023, 06:33 AM
Today I'm receiving a kit of NOID to check out if the injectors are getting Power don't think that's the problem but I'm trying everything.
Old 04-14-2023, 06:39 AM
Senior Member
If the plugs are going black it’s probably an ignition issue not fuel starvation.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-14-2023, 06:59 AM
I'd like to thank you all for your comments I finally got the car running and it's perfect issue was 2 of the injectors was running at 40% Even though I had them clean I read somewhere Injectors can Have an issue again after cleaning so I took them Back again to the shop and they Clean them again And that was the issue Thank you guys
Old 04-15-2023, 06:25 AM
