pkp4911's Avatar
Removing stainless trim from top of doors?
Restoring 73 911 and trying to access bolts that secure trim to top of doors. Either I'm blind or some other means used. Thanks.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Patrick
Old 11-06-2015, 12:01 PM
356graham's Avatar
Held on with plastic clips. Pelican sells metal replacement clips.
Door Moulding Clip (Upper Door Edge)
Part Number: 999-591-326-01-M100
Jeff Graham
'56 Speedster
'72 911E Targa
Old 11-06-2015, 12:17 PM
Top part of inside trim is screwed in, one at front and one at rear. The rear has a small plug over it.
Then unscrew door lock button and it should slide up and off.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-06-2015, 12:28 PM
If you mean the window frame you need to unbolt the whole frame from the door.
Remove inside trim to access bolts inside the door and there are additional allen head bolts under rubber plugs in the edge of the door.
Thats anodized aluminum not stainless.
Post some pictures.
1991 C2 Turbo
Old 11-06-2015, 12:31 PM
pkp4911's Avatar
I can pull window frame. Already pulled guts for window.
Patrick
Old 11-06-2015, 12:48 PM
pkp4911's Avatar
Here is what I'm trying to remove...
Patrick
Old 11-06-2015, 12:50 PM
pkp4911's Avatar
Just the syrup along the top of the door (not window).
Patrick
Old 11-06-2015, 12:51 PM
pkp4911's Avatar
Strip...sheesh.
Patrick
pkp4911's Avatar
Exterior trim pieces. Look stainless, but are anodized aluminum.
Patrick
Old 11-06-2015, 01:01 PM
pkp4911's Avatar
Patrick
Old 11-06-2015, 01:03 PM
pkp4911's Avatar
Figured it out. Thanks guys! (Didn't even break clips! )
Patrick
Old 11-06-2015, 01:27 PM
