944 turbo wheels on 911SC
I have found some 16x7/8 fuch wheels off of a 944 turbo near me. I was wondering what was needed to make these fit on my 78 911SC? I am looking at charts and see the offset significantly different. Do I need large spacers for this fitment? Thanks in advance!
the 944 8x16ET23.3 have more inboard o/s than 911 8x16ET10.6, to use the 944 wheels on the back of an SC/Carrera use 23.3 - 10.6 = 12.7mm spacers though you can go thicker for a more aggressive fitment. Some try to use the 944 8x16 on the front of a 911 but it's not a happy or comfortable fit.
Thanks Bill! Do you know what an aggressive spacer would be? I really want the back wheels to sit flush on the fenders.
for 225/50 a 29mm spacer will be around the max for 245/45 a ~19mm spacer will be around the max I'd keep a little less than max as max entails lip mods and suspension constraints.
