-   -   How to test tach before sending (http://forums.pelicanparts.com/porsche-911-technical-forum/890679-how-test-tach-before-sending.html)
Quickstep192 11-11-2015 08:45 AM
I'm pretty sure my tach from my '73 911 is toast, but I'd really like to know for sure before shipping it all the way from Maryland to North Hollywood Speedo. What type of place would be likely to have the gear to test it?
jpnovak 11-11-2015 08:58 AM
Just need a function generator. apply 12V power and ground. Then put a 12V square wave signal into the tach. sweep the frequency and the needle should move.
DRACO A5OG 11-11-2015 03:23 PM
Put yours in a know good car, I am sure your will find a Pelican in the area :D
Quickstep192 11-11-2015 07:14 PM
Getting the tach out requires removing the steering wheel and column shroud. I'd really feel like I was putting someone out to ask them to do that.
What kind of place would have a function generator?
jpnovak 11-11-2015 07:40 PM
You should be able to pull the tach on a 73. The clamshell is smaller than the earlier ones that require removal.
Any electronics test lab should have a function generator. I have one if you want to send it to TX.
DRACO A5OG 11-11-2015 07:47 PM
No, you do not have to remove the steering wheel or the clam shell.
It is tight but can be done. Just pull out the clock or fuel level gauge and reach in and push. You can also come in from the frunk.
KTL 11-12-2015 07:32 AM
Can you make the assembly of electrical parts diagrammed by Warren in this thread? If so, I think you can test the tach yourself
http://forums.pelicanparts.com/porsche-911-technical-forum/361338-tach-question.html
