-   -   early S caliper question (http://forums.pelicanparts.com/porsche-911-technical-forum/890870-early-s-caliper-question.html)
tonizzos 11-12-2015 08:57 AM
hi friends , i got a set front and rear calipers in a bunch of pieces .... the calipers have been rebuild and i was wondering witch type i got !! :D:D
i think they are early S calipers 69-71 as i do not find any circle ... if i did my researches well hahaha
here some pictures
would realy appreciate any confirmation or infos as i don t plan to use them but would realy lie to know what i ve got
the S ones i think..
http://imagizer.imageshack.us/v2/800...905/iUzqMf.jpg
http://imagizer.imageshack.us/v2/800...908/kOBitt.jpg
http://imagizer.imageshack.us/v2/800...910/tLnERq.jpg
http://imagizer.imageshack.us/v2/800...905/vTbwBd.jpg
http://imagizer.imageshack.us/v2/800...911/HTqOVO.jpg
http://imagizer.imageshack.us/v2/800...911/k8ja6m.jpg
http://imagizer.imageshack.us/v2/800...910/iRGt74.jpg
http://imagizer.imageshack.us/v2/800...905/gFkvLT.jpg
tharbert 11-12-2015 10:53 AM
Does a magnet stick to them? I think the "S" calipers are aluminum.
tonizzos 11-12-2015 11:19 AM
they are.... i weighted also the smaller calipers ....
http://imagizer.imageshack.us/v2/800...633/gk6tQH.jpg
http://imagizer.imageshack.us/v2/800...911/JFYspZ.jpg
patz 11-12-2015 01:33 PM
Send pics to Eric Shea at www.pmbperformance.com or PM Bill Verburg on this list.
jbell959 11-12-2015 02:23 PM
They look like early S calipers to me. I haven't seen any with the "TEST" stamp so I'd be curious what that is, but everything else points to an early set of ATE aluminum S calipers.
manbridge 74 11-12-2015 03:39 PM
Thinner "webbing" on sides of caliper indicates early S. Later versions were thicker and had a smoother look.
tonizzos 11-12-2015 08:48 PM
I think the test stamp is from the compagny that rebuild them....
tonizzos 11-13-2015 01:12 AM
yep, should be the one on the far right ...
http://imagizer.imageshack.us/v2/800...907/I1Bh5l.jpg
djpateman 11-13-2015 03:50 PM
They do look to be early, but not the earliest versions. The earliest versions did not have the notches cut out near the bleed nipples. Also, the earliest I have handled had the same circular machining on the inside of the mount ears as on the outside.
The TEST stamp is very odd, and not something I have seen. The experimental calipers have a "V" for versuch and a numerical identifier.
reddogmotrsprts 11-13-2015 07:30 PM
Who did the restoration of these?
tonizzos 11-14-2015 03:27 AM
UDF Automotive did the Job :::
http://imagizer.imageshack.us/v2/800...633/3yMAVK.jpg
http://imagizer.imageshack.us/v2/800...633/INuxga.jpg
