jarrodblake's Avatar
964 door on early 911
I'm looking for a replacement door for my 70 911. I found a set of doors that are local to me they are off of a 964 c2. I amuse they will fit, however when I started searching for a replacement door. I would see fits 65-89 or 89-94 are the skins different or hinge placement/ type? Other then the side mirror hols I don't see the difference. I just need to know if they will bolt on and fit correctly with little to no modification to the hinges or window frame.
I know there are a few small things like different seals etc...
Old 08-17-2014, 11:12 AM
also the interior light switch will not work (panel on the hinge side different). Getting the doorcard, doorpull etc mounted will also entail some modifications. All doable
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 08-17-2014, 12:56 PM
What's the difference between 65-68, 69-73, and 74-89 doors? Is the door frame and sheet metal exactly the same?
Old 11-14-2015, 09:30 AM
