Dear Friends
I´m rebuilding this 1976 911 and because I´m not in USA and buy parts from pelican for instance it´s not that easy, I wonder what are the sizes or codes for the 2 front wheel bearings 1 rear wheel bearing So, I can try to find out here in Brazil a bearing shop to buy them Thanks Ricardo |
Spiderman
Have you taken the Porsche part numbers to your bearing supplier to have them reference the correct parts. I believe they are reasonably common bearings, every local part store I go to can get them easily.
It appears 76 bearings are identical to 87 so this is what I see on the boxes on my part shelf. Front outer SKF brand, BR2, (smaller unit) more numbers include 346K 339 2H1E 1BI2 that all may be junk Front inner SKF brand, BR6 VP, (larger unit) lots of little numbers I'm sure are junk. I looked on-line, the SKF BR2 and BR6 seem to get you to the correct parts. I've never done the rears.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Air Medal or two
DO NOT use Chinese ! ( you will get to do it again real soon )
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
