Oh What An Idiot I Am
Finally got my car running perfectly,valve adjustment,corner balance,leaks eliminated,etc.so what do I do?shampoo the engine of course, what a fool!!! now I can't get the it started,I have tried to dry out everything,any other suggestions?Thanks in advance,Marty
AutoBahned
take dist. cap off & use blow dryer + sunlight on it
Registered Usurper
Years ago my 240Z wouldn't start after being parked in heavy rain for hours. It had good spark and pumped gas. I called my mech. at home (I was stranded at my office on a Sunday afternoon) and he told me to put the dist. cap in a warm oven. The cap looked and felt completely dry, inside & out, but damned if 10 min. at low heat didn't dry out the unseen moisture and the car fired up immediately.
I bought a new cap next day. Apparently they get somewhat porous with age and can retain enough moisture to become inoperable.
'82 SC RoW coupe |
I'Mm not getting any spark,Marty
does anyone know what the resistance should be on a 77 coil?Marty
AutoBahned
just search on: coil resistance
I'm sure Warren has posted it. |
Have no power going to coil,what do you think?Thanks,Marty
Tru6 Restoration & Design |
