Weber transition port sizes
On Weber 40 IDA/IDT etc., does anyone have any idea the factory dimensions of the fixed transition ports near the edge of each throttle plate? I suspect my recently acquired set has been drilled/enlarged as I'm unable to lean the mixture off idle > about 3800 rpm using different idle, main, air correction jets and float setting.
I can adjust the mixture before and after the above range (confirmed with A/F gauge). Thanks, Sherwood |
From bottom to top:
IDA, IDAP & IDS:
IDT (not IDTP):
IDTP:
Whoa. Thanks for the info Paul. Will try to confirm.
Much appreciated Sherwood |
| All times are GMT -8. The time now is 06:29 PM. |
