As an update, I'm going to give mechanic my DME and he's giving me one of his.
He also mentioned in an e-mail, that the air gap on the crank sensor, could be causing the stalling, if it's not exactly .8 mm. Is that something I can check myself?
'84 Targa: Duel output muffler, cat bypass, performance chip, cup airbox, P-Short throw, Euro H4s, Bilstein HDs, lowered torsion bars, strut tower brace, t-tie rod ends, etc. |
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
A new ICV these days is about $400. I bought a used one for $100 this spring.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
So the plot thickens!!! After I reinstalled my good ICV, I put the "borrowed" good DME in from my mechanic. It ran worse!!!:banghead:
Idle hunted a little at start up and then during warm up, I noticed at idle, it would dip down low a few times and recover. Once I felt it was warmed up enough, I took her out. Almost immediately I noticed that once I laid on the throttle, the car would almost shut down! Sometimes it did completely and sometimes it would abruptly recover and snap my head back. It also would intermittently stall at stops / same issue as before. WTF?! Here's a pic of the DME, is it possibly from an '86-'89 and wouldn't work properly in my early 3.2?? I'm getting very frustrated now.......
Cars Ruined My Life
I think that part number fits 84-89
1986 Bosch Icon Wipers coupe. |
I looked at my records and this was replaced a few months ago, when I originally mentioned an idle hunting issue. My mechanic is saying he now thinks the air gap is off in the crank sensor. He has a way of checking and adjusting w/o dropping the engine. However, I think it could also be a failure of the chip that I installed. I have the 2K version and here's a page from them, saying idle can hunt, etc. That still doesn't explain why the borrowed DME didn't work though...
'84 Targa: Duel output muffler, cat bypass, performance chip, cup airbox, P-Short throw, Euro H4s, Bilstein HDs, lowered torsion bars, strut tower brace, t-tie rod ends, etc. Last edited by Sargepug; 01-05-2016 at 04:15 AM.. |
Just taking her out of storage and still having the stalling issue, she's due at shop on 4/11, to check the air gap sensor at the crank. Any thoughts on my previous post regarding the chip that was installed? Also, how does it make sense, that a good DME swap, actually made the car run worse? It was like when I will giving it throttle, the power would be low, then greatly surge. Very odd....
Going into shop tomorrow and starting to really notice that the weather plays a big part. When it's damp out, it stalls almost at every stop. Yesterday, bone dry 72 degrees and I drove her for 150 miles. Most of that was highway, yet she didn't stall once, after making a good 20 stops along the way. Got close a time or two, but no stalling. Thoughts???
So it sounds like humidity/moisture plays a role, which then sounds electrical to me.
What is the condition of the spark plug wires? Pop the engine lid and run the car in a dark garage. You'll see if the spark plug wires are grounding out somewhere.
weather wise, could It have to do w/ them wanting to check the air gap on the crank sensor? They said if it's not exactly .8 mm, that could cause stalling. Maybe the bad weather days / air pressures being real off, wreak havoc like this if gap is off?
Troll Hunter
Does Gaspar know about your chip? I can't believe this is still going on.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
I hear you on the time frame, however, car was in storage since Nov, so a lot of down time....
FINALLY FIXED!!!
![]() After all the troubleshooting last summer into late fall and then after winter storage, It was the air meter! Swapped in a good used one and she's perfect now. Owner of shop was a gem (because I've been very patient thru this grueling process and a great customer) and didn't even charge me for any labor (hours to go thru eveything on the car to finally put this to rest)I walked out paying $150 for the part. ![]() Thanks for all the help here and I hope this solves somebody else's problems!
'84 Targa: Duel output muffler, cat bypass, performance chip, cup airbox, P-Short throw, Euro H4s, Bilstein HDs, lowered torsion bars, strut tower brace, t-tie rod ends, etc. Last edited by Sargepug; 04-30-2016 at 07:31 AM.. |
Sarge, was it this part? Only $150?
I thought they are a lot more. Was it a used one?
FWIW, these guys refurbish / rebuild AFMs...
Air Flow Meters - Bavarian Restoration Glad to hear you hunted down, and captured, your issue. Gotta love the moment when frustration turns to elation! Last edited by famoroso; 05-01-2016 at 06:51 AM.. |
