which rear bumpers for backdate project?
I have a 1985 3.2 Carrera with standard flares in rear. Which is the correct year/version of the back bumpers that will fit, or does anything I find have to be reworked to fit the flare?
Thanks,
Mike
Old 08-29-2015, 11:21 AM
Rescuer of old cars
Arne2's Avatar
If you want steel, you are best off having a pair of LWB (69-73) bumpers modified.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 08-29-2015, 01:00 PM
Definitely want steel. So nothing will work without cutting and welding?
Old 08-29-2015, 10:10 PM
Almost Banned Once
sc_rufctr's Avatar
Unfortunately no. Do some searching here. I've seen steel ones done DIY.
Or good quality Fiberglass reproductions?
- Peter
Old 08-29-2015, 10:35 PM
Mike,
I spoke to Dave at TRE a few weeks ago about this subject. They used to modify LWB steel bumper corners for customers who were backdating. Unfortunately, they no longer provide this service.
Dave told me that the RS flares are very close to SC/Carrera flares (both start and end points) but the mounting brackets will require modification.
Lou
Old 08-30-2015, 04:52 AM
Been here a while
Stoddard has them
http://www.*************/stoddard-s-sport-purpose-line/exterior.html
Old 08-30-2015, 05:04 AM
Yes, I might have to bite into new RS parts from Porsche. That look slike best fit. Boy, they sure command a high price. Thanks.
Old 08-30-2015, 04:02 PM
Got them - about $750 each side. Very nicely made from Porsche.
Old 09-16-2015, 02:05 PM
Mike, I've been following your backdate thread. Great stuff! About the rear bumpers from Porsche: are they RS-flared? Would be curious to see how they match into the 3.2 flares. Please post pics!
Old 10-03-2015, 03:16 PM
I am traveling right now but back in Lake Forest late next week. I will start stripping the bumpers then, so it will be a little while.
You can come over and check out the parts. PM me if you want to inspect them.
Here is the link that had me thinking it should work (check post 37):
st rear flares
I will post up once I start taking it apart.
Mike
Old 10-03-2015, 08:35 PM
Are you looking to buy rubber bumpers I need to get rid of mine
Old 10-04-2015, 01:20 AM
I will be using chrome bumperettes thanks.
Old 10-04-2015, 09:01 AM
pors1968's Avatar
If i read right porsche sale RS rear bumper for 750.00 cheaper than other i seen.
Old 10-04-2015, 09:18 AM
To clarify, it is $750.00 per side - $1500 total for genuine Porsche parts.
Old 10-04-2015, 01:32 PM
Here is how the RS flares will match up. I need to modify the mounting flanges of the bumpers to remove interference, but the curve looks spot very close from here:
Old 10-30-2015, 05:29 PM
Installed loosely (cleco-ed without seals installed). They fit right.
Old 11-23-2015, 07:32 AM
