San Diego, CA
Cleaning WUR
I have read about a screen on the WUR that can be cleaned. Is this visible when the WUR is removed or is disassembly required? If not, can anything else be cleaned internally or just shims added or removed for adjustment?
Just been researching this as well. This link helped
http://b2resource.com/PDFs/wurservicing.pdf Basically there are about four or five individual mesh screens that get finer and finer. You literally have to gouge them out. Mine didn't clean with Carb cleaner as they were too rusty. |
San Diego, CA
Great Info. Thanks for passing it on!
Reiver
Good info but the opening statements are incorrect. Bosch does consider the WUR re buildable but only thru their sanctioned re builders and the parts are available but Bosch only provides the factory parts to those same sanctioned rebuilders.
If you want contact info drop me a line....no connection with Larry but he rebuilt my euro Wur and does so to higher tolerances than Bosch specifies (tests each). It works beautifully.
De Oppresso Liber Strength and Honor 5th Legion |
