crashr's Avatar
Question Cleaning Outside of Tranny?
I've been reading through some of the old posts and they talk about cleaning different parts of the engine with a pressure washer. My transmission is covered with about an inch of goop and I wanted to clean it off. Can I use a citrus type cleaner and then use the pressure washer on it. If so, is there anything I should be aware of. If no, how else can I clean it?
Thanks ahead of time,
1975 Widebody 911 3.2 Euro
Old 11-30-2002, 08:48 PM
rickeolis's Avatar
Porsche Crest Deja vu??
Funny, it seems like just yesterday we were having this discussion...
Winter Project:
-Rickeolis-
1986 Corvette
Old 11-30-2002, 10:28 PM
crashr's Avatar
Sorry about that I didnt' read this thread when I searched because of the title. My apologies.
Old 11-30-2002, 10:45 PM
JR911's Avatar
Dennis,
I used Simple Green full strength and a stiff nylon brush (went through about 3) when I cleaned the oily build-up on my engine, it did a super job! I had to repeat the cleaning in some places....used water to wrinse off the oily mess.
Don't be in a real hurry, the more you can scrape off with a putty knife or screw driver etc. the easier the job is.
You could try spraying the trans with Simple Green or similar products, (full strength) let soak for 20-30 min. then use a high pressure sprayer, this will help save some elbow grease when you have to scape what is left.
There really is a clean, bright trans under all that goop!!
Go for it!
J.R.
JR911's Avatar
Just read the other post.... Oil Eater is the stuff I liked....seems better than Simple Green.
J.R.
Old 11-30-2002, 10:54 PM
