-   -   Would like to try a compression & leakdown test at home. (http://forums.pelicanparts.com/porsche-911-technical-forum/893010-would-like-try-compression-leakdown-test-home.html)
sugarwood 11-29-2015 09:30 AM
There are many seasoned experts here, but some of us are relatively new to this hobby.
For my own edification, I would like to remove the mystery of both these "exotic" procedures by attempting both on my car.
I have read a bunch of very old threads, but wanted to start a new one for my very stupid and obvious questions.
First, I will start with the tools required.
Can someone recommend a compression gauge that works with the 3.2 engine?
Is this the dual gauge leakdown tool I need to buy. ?
Do I need an adapter to connect the leakdown tool to my 3.2 spark plug hole? Do you make one or buy one?
What is this part for?
I have never removed a spark plug from the 3.2
As a first step, before ordering tools, does it make sense to make sure I can loosen all 6 spark plugs using the toolkit?
If they are seized, then buying these tools would be a pointless.
sugarwood 11-29-2015 09:53 AM
http://forums.pelicanparts.com/uploa...1232426740.jpg
I have never dealt with TDC or anything related to the distributor.
How exactly does one turn over the engine to find this marking (rotate the crankshaft pulley) ?
Do I need to remove any belts before doing this?
cpcooper 11-29-2015 10:02 AM
I'd say start with a good quality spark plug socket with a foam insert to hold/protect the plug. 911 spark plugs are about 5 inches below the cam covers, so the insert keeps the plug from dropping out of the socket when you reinstall it. Also, a 3/8 ratchet, maybe with a flex head, and 4 inch extension. CAUTION: You are going to be removing spark plugs from an aluminum head. They should be initially tight, but then thread out smoothly. If it doesn't feel right, might be best to gently re-tighten and, provided the car runs OK, reconsider doing the tests. On the way back in, turn the extension by hand so you can feel the sparkplug thread into the head and you are ABSOLUTELY SURE it's straight before tightening with ratchet.
The leakdown setup you are considering looks like the same one I got from Harbor Freight. I also got my compression gauge there (no special adapter required). I like Harbor for stuff I seldom use. Snap-On for things I use every day, or Craftsman if I can't afford Snap-On.
The other tool you provided the link for looks like it screws into the spark plug hole and then you can attach a leak down tester or compression gauge to it. This would be handy, although not essential, as both the compression and leak down testers have a brass fitting on a rubber hose you have to finagle into the spark plug hole which, as previously described, is down at the bottom of a hole where you can't see it.
Go slowly and follow instructions that come with both test instruments. Above all, don't force anything on the way back together. Wish you were closer, I'd share my tools. Maybe someone else on the forum is close to you and will volunteer.
sugarwood 11-29-2015 10:22 AM
Now I'm a little intimidated about stripping the threads. I will be extra careful when rethreading the spark plug, and make sure not to force anything. It should spin in pretty freely for the first few turns?
cpcooper 11-29-2015 10:48 AM
Didn't mean to overdo it on the sparkplug thread thing. How about this: Once you've broken the plugs loose with the ratchet and they are turning freely on the way out, remove the ratchet from the extension and turn it with your hand. You'll feel a little resistance but you should be able to continue to unscrew the plug by hand. This is how they should feel going back in. You should be fine if you take your time and, if something feels wrong, ask for help.
I turn my engine over by hand by turning nut on the alternator pulley.
sugarwood 11-29-2015 10:59 AM
Will do on the spark plugs.
I didn't realize that turning the fan nut can turn over the engine.
Is this the standard method?
I will go try that now.
sugarwood 11-29-2015 12:40 PM
I tried turning the fan bolt and the fan pulley just slipped as the belt stayed in place.
I guess this means my fan belt is too loose ?
In fact, after a belt change, is moving the crank pulley a good test to see if your belt is tight enough?
mdwracer 11-29-2015 01:17 PM
a couple points to look at...
Remove all spark plugs, this makes engine easy to turn over.
Leakdown should be performed on a cylinder when its at its firing time ( its TDC ).
Pull the distributor cap and line the crank TDC mark WHEN the rotor is pointing to number 1....Insert Leakdown tool for #1 and perform test.
Rotate fan clockwise...while pushing in on belt(keeping it from slipping)
The next mark on crank that lines up will be Cyl 6. Perform test on that cylinder.
The cranksaft turns two revolutions to fire all six cylinders, so you will do #1, #6, and #2... then one second revoultion of crank sprocket do #4, #3, and finally #5...
At some point while the plugs are out, perform the compression check... NOTE: make sure your compression guage when fully inserted does not extend any further than a normal spark plug does...(You don't want contact!!)
I also like to crank engine with the throttle wide open for test on all cylinders.
Mike W
VFR750 11-29-2015 01:38 PM
When you wrench the fan, push on the belt like a tensioner would. That's how you get the belt to grip and turn the engine.
VFR750 11-29-2015 01:41 PM
If you thread plugs by hand it's hard to cross thread them. Just need to see how it feels.
If there is anti seize on the threads or some carbon build up they may resist a little when coming out.
New plugs without anti seize should go in pretty easy.
Ton504 11-29-2015 03:07 PM
Mike W
New Guy here.
I was wondering why do you need to perform a compression test if you just completed a leak down test? The leak down test gives you all the info the compression test would, no?
And again I'm new here and also new to flat sixes. Should you hold the crank so it would not turn over once the cylinder is pressurized?
doublebuffle 11-29-2015 03:26 PM
For sure, if you press in on the belt while turning the fan bolt pulley, removing sparkplugs is not required. My favorite way is using a breaker bar and the fan nut. My least favorite way is using the fan tool in your porsche tool-kit.
Arriving at the notches with accuracy is something that takes a little practice. Don't go backwards.
doublebuffle 11-29-2015 03:28 PM
Also, if you have the original spark plug tool, a special plug wrench is not required. The factory tool works very well.
mdwracer 11-29-2015 03:50 PM
In a perfect world with each cylinder on its TDC, the crank won't move when you put the air to it...
I really like doing a compression check first and doing a leakdown on the lowest reading compression cylinder on a presumably good engine/engine that has been running recently.
Leakdown tests are good for buying engines that are on pallets before you put them in the car only to find out that you have a burnt valve!!
It is fair to say that an engine could have higher than desirable leakdown percentage but still achieve a decent compression number.
Mike W
Taxi! 11-29-2015 04:57 PM
Sugarwood,
Not to make you more reluctant, but when I removed my spark plug boots for the first time so I could change the plugs, a couple of the boots ripped, leaving a 1/2 inch rubber ring around the top of the spark plug. This made using a spark plug socket with an insert to grip the plug after it's been unscrewed from the head (like cpcooper suggested) impossible because the leftover boot prevented the socket from completely fitting onto the spark plug. So I had to buy a spark plug socket without an insert to unscrew the plug and then use needle nose pliers to fish the plug out. Not a big deal in the long run, but I didn't immediately notice that the boots had torn so I spent a while trying to figure out why the spark plug socket was turning but nothing was happening. An extendable mirror helped figure it out.
sugarwood 11-29-2015 05:15 PM
It was pretty easy to move the crankshaft pulley!
For a while, I was pressing the left side of the belt, and the fan pulley just slid.
Finally, I pressed the other side of the belt (the one that is more obscured. passenger side), and it moved very easily.
Thanks, I feel a sense of accomplishment from something as trivial as this.
doublebuffle was right. I went right past the fan housing marking. It almost seemed to snap right past it.
http://i67.tinypic.com/30xfxgj.jpg
sugarwood 11-29-2015 05:20 PM
http://forums.pelicanparts.com/uploa...1118700053.jpg
Taxi, I will be careful while pulling the boots. Thanks for the head's up.
My next step is to try to loosen the spark plugs with the special toolkit thing.
Are there any basic tricks?
It seems like very limited access, at first glance. Do I remove anything else first?
The allen key is used to get some proper torque to break the spark plug loose?
Is that ever not enough?
sugarwood 12-01-2015 08:03 PM
http://i68.tinypic.com/11bus6g.jpg
The 911 spark plugs are the first in my life that genuinely scare me.
I have changed spark plugs on many cars and machines since I was a teen.
But, I have never seen spark plugs that are 100% hidden under a valve cover.
First the good news! I tried the spark plug tool tonight.
Boots came off very easily, and both plugs I tried break loose very easily.
I was barely able to get some leverage using the L-key, but it was enough.
I used my other hand to stabilize the plug tool on the plug so I wouldn't crack it with crooked twisting.
I screwed them back in, and gave a light tug once it was seated.
It took me a long time to get the middle boot reseated on the plug.
I just couldn't find the seat, and I must have been finding a false seat.
It finally clicked into place when I dramatically changed the angle of the boot.
When working with blind spark plugs, here are things that scare the hell out of me:
1) What would you do if you cracked the ceramic part of the plug? How would you fish it out?
2) How do you even re-thread the spark plug?
I can totally see never being able to get it back in, and just spinning it blindly.
It was hard enough getting the boot back on!
3) What if the spark plug falls out of the tool, while still in the cavity? How would you extract it ??
wdfifteen 12-01-2015 09:43 PM
I've never thought of that. I started with Dodge slant sixes, then VWs and 356s. Having the plugs hidden seems totally natural to me.
Nice photo!
boyt911sc 12-02-2015 04:26 AM
Overcome your anxiety............
Sugarwood,
It is normal to be anxious when doing things that your are not used to do. Try to overcome your anxiety and do not over think every single step in the process. Relax and enjoy learning this new experience. Remove the intake valve cover and not worry about oil spilling out. With the valve cover removed, you would have a better view of the spark plugs. Facing one side of the engine, note the orientation of the spark plugs. They are threaded to the cylinder heads at a slight angle to the right.
You should be able to answer the above questions yourself using common sense. And if you could not figure out the answers to 2 of the 3 of the above questions, your are mechanically challenge and would take a lot of training and practice to become an average DIYer. But if you want to learn and do these maintenance work and enjoy the experience, you need to relax and tell yourself it is doable. You could do it. I was in similar mental state when I first attempted to work on 911. Maybe even worse because I get stomach upset and have to run to the bathroom several times before I could complete an engine drop. As of today, I am preparing a start up for the 14th motor I rebuilt.
We all would make mistakes and some are silly ones and others could be disastrous. I know for a fact which cam go to the right side or to the left side. And I still inadvertently installed them backward. The problem has been corrected and the rebuild is in its final stage.
http://forums.pelicanparts.com/uploa...1449058307.jpg
sugarwood 12-02-2015 02:43 PM
Thank you for your inspiration.
1) If you crack the plug off, can that top valve cover be removed with the engine still in the car?
I can barely see down there, and no side view, so it's not obvious to me.
2) It took me longer than I care to admit just to get the boot seated again.
So, threading something seems a whole different ballgame.
Just keep trying until it catches?
3) Can you fish it out through the hole? Fingers? Magnet tool?
When I stuck my finger in there, I could barely touch the spark plug tip.
So, I can easily envision it falling out of reach. Then what? Step #1 ?
sugarwood 12-05-2015 02:40 PM
I loosened the 3rd spark plug today.
All 3 on the left side came loose very easily, so I am no longer worried about seized plugs.
A size 10 hex key socket bit was easier to maneuver than the allen Key.
After #3, I realized I had not re-installed the first 2 boots correctly.
I pulled them, and this time, I got the metallic "snap" sound when fully seated.
and..............
I was about to try fully removing a spark plug and reinstalling it, but chickened out at the last second.
Just worried I would not be able to re-thread the spark plug back in.
So, I did take a closer look at the spark plug valve cover (Is there a name for it?)
If I could not re-thread the spark plug, I could just remove the 6 bolts, remove the cover,
and getting a much easier access at rethreading the spark plugs, right?
In fact, is this the preferred method? 6 bolts might be quicker than blind threading.
Zaz 12-05-2015 03:35 PM
I always remove the valve covers to access the plugs. Easy as pie.
sugarwood 12-05-2015 06:36 PM
Ok, that's good to know I can just remove them, if I get stuck.
Do you need to install a new gasket each time you remove the upper valve covers to access the spark plugs?
What exactly are the upper valve covers for?
Are they sealing oil like the lower valve cover?
I'd think not since the "dust boots" on the spark plug boots are not really sealed.
jlex 03-29-2016 06:29 AM
If you're careful, you should be able to re-use those upper valve cover gaskets if you need to remove the cover for any reason. I can see you doing a valve adjustment next, so you might as well order the gasket kit and have it at hand if you tear the gasket somehow. Yessir.... you're in for lots of fun doing your first valve adjustment SmileWavy
Bob Kontak 03-29-2016 08:06 AM
Originally Posted by Ton504 (Post 8896595)
New Guy here.
Good questions. I do remember Bruce Anderson's 911 Performance Handbook saying he pays more attention to one test than another. And I think it's a bit of leakdown with good compression does not mean the death rattle is present. I have the book at home so if I remember I can check tonight.
Yes on holding the crank. If you take the plugs out it will spin easily with air pressure applied to a single cylinder.
Bob Kontak 03-29-2016 08:12 AM
The upper valve assembly is oiled. Rockers go up and down fast and oil will be popped upward and also slung upward by the cam lobes. They seal exactly like the lowers valve covers.
Cover gasket covers the spark plug hole mating surface to the engine.
CCM911 03-29-2016 10:47 AM
Sugarwood, I am going to say this in the nicest way possible:
Quit being such a spaz! Get in there and poke around. You will not hurt anything, as long as you proceed with a modicum of caution. I went from knowing nothing to dropping my engine multiple times. Just grab someone from your PCA region and have at it. Really, the more you keep thinking, the more you are freaking yourself out. You will be fine. I promise.
Now get out to that garage and make us all proud. :)
