air scoop
I am thinking about mounting an air scoop on the engine grill on my 75 911S to get more air to the engine and hopefully get it to run cooler. It's 15 3/4" x 6"x 13/4 cast Al. Easy mount. What problems if any might this cause.
Old 11-30-2015, 10:46 AM
Oh Haha's Avatar
It MAY get you a little more air{at speed} but you'd be better off upgrading your oil cooling system or at least make sure it is working properly. What temps are you seeing that have you concerned?
Pacific Blue
Wayne
Old 11-30-2015, 01:41 PM
RFP RFP is offline
RFP's Avatar
It will do virtually nothing for your engine temps and will mess up what may be an otherwise perfectly good deck lid. If you need more cooling, follow Oh Haha's excellent suggestion.
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 11-30-2015, 01:55 PM
It's been discussed and tried by quiet a few here (use search function) and the end result was negative. The fan pulls more air in than the scoop can provide unless you are traveling at race track speeds. Better look into additional oil coolers.
1986 3.2 Carrera
Old 11-30-2015, 02:26 PM
6 cylinder symphony
What they said:
At low speed, it's your oil cooling system that needs improvement. Either the oil cooler, fans or both.
At high speed, it's the spoiler configuration.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 11-30-2015, 02:46 PM
Not sure what condition your engine is in, but recommend avoiding the scoop and chasing things in this order:
- Get cylinder fins/heads/oil cooler clean
- Verify engine oil thermostat is working correctly
- Install 11-blade fan (if you've got a 5-blade for some reason) and overdrive pulley
- External t-stat and cooler
Old 11-30-2015, 05:49 PM
