Driver's seat bearing
Hi,
My seats has quite a lot of movement from left to right and the previous owner mentioned that some of the wheel bearings were lost. Is it true that the seat rails have wheel bearings? Is this a typical problem with these seats? I appreciate any suggestions how to fix this as the seat doesn't feel stable during cornering. It is properly bolted. Thank you. 76 targa
1974 911 coupe 4 speed |
Spiderman
There are no "bearings" that I know of in the seat sliders. I'd suggest taking out the 4 bolts of the wiggly seat and looking at it outside of the car. Should be easy to do.
At least it is with my 87's seats. Maybe a weld has broken somewhere underneath.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Concur...never heard of any bearing...take Jesse16 lead on this
Seat Roller
I had a set of seat sliders that had 4 ball bearings per rail (I think most do - but I wouldn't call them wheel bearings, seats definitely don't need those...) - if one ever got out of the rail I imagine it would have wobbled.
The balls ride and slide back and forth in a small channel on the inside of the rails. Mine wore a few divots in certain positions of the rail - I suppose from where the the seat was normally positioned. My guess is that your seat sliders are shot. Gordo
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 03-12-2018 at 04:08 PM.. |
Thank you
Will take the seat out to investigate further.
