-   -   engine wants to start, but won't. (http://forums.pelicanparts.com/porsche-911-technical-forum/89325-engine-wants-start-but-wont.html)
porsche_virus 12-01-2002 12:40 PM
Okay. A last ditch cry for help before I have it hauled away. This is a '74 911, 2.7 CIS. I recently put the engine back in after getting the cam timing set correctly and replacing a few oil seals and gaskets, along with piston rings.
I just looked under the pop-off valve and noticed a lot of really black oil in there. Is that normal?
It'll try to start, and maybe run for like 2 seconds, but then dies, all the while pouring white smoke out the exhaust. Any ideas? I've spoken to a few people who are certain it's CIS related. I've adjusted the mixture rich and lean a LITTLE, but am not sure it's changing anything. I've checked all the injectors and they are spraying. Could it be a fuel filter or regulator? Here's a video clip with sound for you all to ponder:
http://www.sunflower.com/~kcmoore/wontstart.wmv
I know I have made a few enemies here with my ignorance, but if those of you who have not decided to hang me yet could lend some advice, that'd be swell.
Thanks in advance.
k9handler 12-01-2002 12:43 PM
make sure the timing is set correct...I had the same problem when I added my new ignition, I was 180 degrees off! I am no expert...just my .02
porsche_virus 12-01-2002 12:45 PM
timing...
Yes...distributor is in correctly and wires are in the the right spots. I've checked that a dozen times, just to be sure, because it seems to be the first thing everyone suggests :)
Bill Douglas 12-01-2002 01:14 PM
If it ran ok before you pulled it to bits it means the mixture should be fairly much correct. I wouldn't change that.
I suspect it's just having trouble burning off the assembly oil. A good idea might be to get a spray can of engine start (mainly ether), and spray that into the air cleaner until it is running ok.
Good luck, and well done doing the new rings etc job :)
bell 12-01-2002 01:15 PM
did you double check everything that was unplugged to get the engine out?
to me it sounds as if the fuel is shutting down as soon as it sees it start to turn over. i'm not an expert with cis though.
Jbabic 12-01-2002 01:45 PM
It's me Jerry,
I know you want it to start, but without knowing what pressure you are delivering to your fuel distributer, your shooting in the dark. a fuel pressure gauge will allow you to determine the issue. of course cam and dist timing eliminated.
you have compression, you have spark, all you need is the right amount of fuel/air ratio.
Tyson Schmidt 12-01-2002 05:00 PM
Lots of oil on the bottom of the pop-off valve. White smoke when it does fire.
Sounds like oil fouled plugs to me. Did you overfill the oil?
Pull out the plugs and look at them. If they are fouled, clean them off with parts cleaner, dry them, then heat them up with a lighter to burn off what's left and try again.
stlrj 12-01-2002 05:00 PM
Sounded just like that when my air boot popped off. You might want to make sure it's sealing at the air flow meter and the throttle valve.
Cheers,
Joe
RoninLB 12-01-2002 06:45 PM
a long shot.. but do you have an ignition kill on an alarm system??
bigchillcar 12-01-2002 07:50 PM
Virus,
I've got a '74 myself...sure wish I was closer to help out. I see you've discovered as I have that owning a mid-year car invites a lot of unwelcome criticism from other early and sc model year car owners. The jokes got old to me well over a year ago...
Anyway, I'll help you take a crack at it. Starting with the fuel pump, can you hear it 'whining' ok? I would think that if your injectors are spraying you have some pressure at least. Next in line is the accumulator. It maintains pressure in the lines when the pump is off. Common failure here is the internal diaphram. If it's leaking fuel out the back, the car won't start. Next is the fuel filter, ought to change it when plugs are changed. From there it enters the fuel distributor. When you turn the key, first the fuel pump turns on and then cranking introduces air. The air sensor plate in the FD will rise, thus metering fuel out of the FD to the injectors. The injectors are spring-loaded and will open when the appropriate pressure (45 psi) is reached and will spray...continuously, hence the name CIS. If the sensor plate is out of adjustment, it will need correction. The FD has an upper and a lower chamber. Between these, this area is controlled by the warmup regulator (WUR). It limits the degree to which the control plunger in the FD can be lifted for a given airflow into the engine, remembering that an arm from the air sensor plate physically raises or lowers this plunger. The WUR is mounted on the engine so that an internal 'thermosensor' knows the engine is cold and allows the plunger greater travel (richer), as the engine warms, the control pressure will decrease and lean the mixture...if it's working correctly. Expect cold-start problems if it isn't. There is also a cold start injector controlled by a thermoswitch when the key is turned on. This injector will fire if the temperature of the engine is less than about 100 degrees and will fire for a few seconds during the starting cycle. Later cars have an auxillary air valve to modulate automatically the airflow to the sensor plate during warm-up. Our '74 model cars have a hand throttle for this purpose instead to maintain the proper idle during warming. Hope this part can help you troubleshoot some.
Btw, have you checked your points? Mine closed up a year ago and then again this past weekend returning from Memphis on I-40. It for sure won't start if this is the case. Remove your distributor cap, pull off the rotor and check. They should be gapped at about .012 mm.
Good luck...'74 year car folks have to stick together around this place!:D
Ryan
bell 12-01-2002 07:58 PM
Originally posted by bigchillcar
[B] I see you've discovered as I have that owning a mid-year car invites a lot of unwelcome criticism from other early and sc model year car owners. The jokes got old to me well over a year ago...
i don't mean any disrespect because your post is thorough and will probably help virus......but where did that come from?!?!?!
bigchillcar 12-01-2002 08:42 PM
Bell,
I see you drive an '85. Sell it and buy a '74-'77 model and start paying attention to what you read about them as I have over the past year or so. Simple.
:rolleyes:
Ryan
porsche_virus 12-01-2002 08:44 PM
a different post...
That came from another post I had concerning valve timing...but it's been taken care of now. Here's some of the comments from it:
"I'm appalled to hear that you don't know the timing specification! After all the good people here who took their time to try and help you with cam timing, you didn't even try it, did you? You lead us to believe you had gone back and timed the cams from scratch like you should've from the start, so then we all discussed timing the distributor, etc., while all along you were just looking for another shortcut solution. Dozens of posts with step-by-step instructions and encouragement all for naught. You won't get another moment's help from me. I have NO sympathy"
"You never even pulled your cam nut did you, despite two threads that turned into complete wankfests.
If you don't put a rod through your case, someone needs to come out there with a shotgun and put that poor motor out of its misery."
I'm no mechanic, nor do I have the money to pay one right now. I just want this thing running so I can sell it ASAP and get my garage back.
bell 12-02-2002 04:59 AM
Bell,
:rolleyes:
Ryan
what!?!?!?.......now you're just being silly :D
virus and big chill.......i now see where that came from
bigchillcar 12-02-2002 05:22 AM
welllll, maybe we'll give you a chance Bell...;)
Ryan
k9handler 12-02-2002 05:57 AM
I know that mine needs a new WUR, but I have just dealt with it...not easy to start, but usually two-three cranks will get it. So instead of spending $250 on the WUR...I will spen over $10,000 on the 3.6 transplant! Hmmm...sounds good to me.:D
Superman 12-02-2002 08:30 AM
Sounds like ignition is working, though making sure plugs are not fouled is good advice. Also sounds like the cold start valve is working. The CSV sprays during startup....the duration depends on temperature. If your six regular injectors were not spraying, then I would suggest that this is the problem. Since they are spraying, I say it sounds like there is a huge vacuum leak in the air box. If the vacuum created by the engine in the air box were unable to suck the air flow sensor plate upwards, then guess what would happen. The car would start (on the CSV alone), run a couple of seconds and then die.
crashr 12-02-2002 09:17 AM
I'm confused, I thought you could start your car with the airbox cover off, wouldn't this create one massive vacuum leak?
Superman 12-02-2002 09:41 AM
Yes, with the cover off (the horn thing that is held on by two rubber straps) the car will start just fine. If there is a huge leak elsewhere, then the sensor plate behind the air cleaner will not be sucked upwards enough to make the six regular injectors spray. YOu might try starting it while someone raises the sensor plate with a finger.
johnco 12-02-2002 10:33 AM
my 74 starts with the cover off. starts with the CIS rubber boot off also. next time I try that I'll make sure the window is rolled ALL the way down and it's not in gear when I reach in thru the window to hit the key. and also that the car is not under my carport. hehehe
Superman 12-02-2002 10:44 AM
Nope. If the rubber boot at the top of the CIS unit (the one between the throttle body and the sensor plate) is off, then your car will start and run only as long as the CSV is spraying. The six regular injectors will not spray and the car will not run longer than a couple of seconds. May be a few seconds in a really cold environment. If your car runs without that boot on, then there is something really wrong.
johnco 12-02-2002 11:09 AM
I'll have to tell that to my car. actually, the sensor plate was set too high after slipping off the little spring clip. but it did start and did run. right into the sawhorses and washing machine in front of the car before I got the key off. a few seconds that seemed like an hour. I wasn't actually trying to start the car, just powering up the pump and turned the key a tad too far. you can raise the sensor plate with your hand and the engine will run without the boot. I've done it many times and my car runs fine
bigchillcar 12-02-2002 12:16 PM
Boys, boys....!:D
Holding up the sensor plate will manually cause the plunger in the fuel distributor to rise. This allows pressure from the bottom chambers into the top ones of the FD, thus equalizing pressure. This means that the springed diaphragm in the FD may then travel downward opening the valves leading to the fuel injectors.
Or maybe it's just because the '74 was such an awesome car! Easy killers, easy... ;)
Ryan
Superman 12-02-2002 12:48 PM
Well, I think you guys understand these things at least as well as I do. That little incident with the washing machine and sawhorses perhaps was due to the cold start valve alone. Again, I think you guys know how this system works.
I've done this before too. Boot off (or some other major vacuum leak). Engine goes VROOOM die. VROOM die. VROOM die.
johnco 12-02-2002 01:24 PM
bigchillcar,
like you said, must be the 74. I can leave my car idling with the boot off. only when I raise the plate up too high or push it down too low, does it die. damn middle year cars! haha Then again, I had a 924 20 years ago that would start and run with 3 injectors disconnected after an engine fire burned the fuel lines. never figured that one out either.
Superman 12-02-2002 02:02 PM
I think you guys are pulling my chain. If the boot is removed so that the air flow sensor plate stays at rest, then there is no way the main injectors should be spraying. I'm going to have a cup of coffee now, so be careful what you say.;)
Tyson Schmidt 12-02-2002 06:27 PM
If the electrical connector is removed from the fuel pump shut-off switch, then the fuel pump will run even if the sensor plate is fully closed. So, it is possible that a car could run with the boot off, and the mixture set rich.
