tensioner question
Is there an easy way to check if a chain tensioner upgrade has been done on my 1970 911 T ?
Well if you mean to oil fed, then yes, there will be an oil line entering each chain case cover. If you mean to the 930 style then the only way is to remove the covers and inspect.
Post a picture of the chain covers......
Tony |
Gunga Galunga
For this, yes. Check out if you have the oil lines described here:
Pelican Technical Article: 911 Carrera Chain Tensioner Upgrade If so, then you had that update. |
That was easy. Thanks
