3.2 Injector batch squirt question
If the firing order of the flat 6 is 1-6-2-4-3-5, why did Porsche batch squirt cylinders 1-2-3 and 4-5-6 as groups? Is there a batch squirt to each bank every crank revolution or every other revolution? If a bank is getting a squirt every other revolution, that leads to a relatively huge difference in time delay before the respective cylinders of a group consume the fuel. For example there is a 600° firing difference between cylinder 1 and 3, but one squirt. Am I missing something?
Megasquirt 3 pro has the option to set up as semi-sequential but requires pairing the injectors. I would like to pair them like the firing order 1-6 and 2-4 and 3-5. This would result in a 120° difference in firing between grouped injector pairs with one squirt. Thoughts? Thanks, Dan |
I've been trying to figure this out myself and there is conflicting info out there. Some folks say the Motronic injection is "bank-to-bank" and alternates between bank 1 (1-2-3) and bank 2 (4-5-6). I assume they would get 2 squirts per cycle (1 squirt per revolution).
But Sal Carceller, who has clearly devoted much time to the Motronic system, has stated that all 6 injectors fire simultaneously (again, divided over 2 squirts per cycle). |
Megasquirt support forum member said to pair them as 1-4 and 6-3 and 2-5?!?!? Which would put pairs 360° apart. I'm pursuing the reasoning behind this approach......
"But Sal Carceller, who has clearly devoted much time to the Motronic system, has stated that all 6 injectors fire simultaneously (again, divided over 2 squirts per cycle)."
That means true batch squirt! They are definitely wired separately, bank 1 vs bank 2. Perhaps wired like this just for electrical load carrying reasons and all still fire at the same time/duration. :confused: |
Yes, I think you have the correct pairings for semi-sequential. This link should help explain semi-sequential injection.
Realizing that they squirt half as much every rev, makes it all logical and plausible for me. I can finally get back to wiring in confidence. |
What setup are you using with your MS3? ITBs?
Carrera intake/throttle body with Vortech Supercharger.
| All times are GMT -8. The time now is 03:54 AM. |
