Engine Yoke from Ebay?
Any every used one of these before? New Lower Price Porsche 911 VW 5 Arm Engine Stand Yoke "The Original" | eBay
Good or junk?
Old 11-30-2015, 08:16 AM
0396's Avatar
Many are happy with this unit from ebay.
As for myself, I rather buy one from our host.
If your motor is a type 4 or early 6 cylinder I think any 4 / 5 arm will do. For turbos , 993 vram I would feel better if it were the 5 arm from our host. Just my .02
Old 11-30-2015, 08:24 AM
I bought one of these from eBay but have never used it and probably never will. If you are interested, PM me. $50 including shipping.
Tom
Old 11-30-2015, 08:43 AM
^ I'd be interested in that if Krieger passes. his thread, so only fair he can have first right of refusal
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 11-30-2015, 08:59 AM
Tom
Do you remember which vender. 4 or 5 bar?
Old 11-30-2015, 10:12 AM
Pm sent
Old 11-30-2015, 10:30 AM
wdfifteen's Avatar
I have one. Looks well-made. Fits, but the arms aren't long enough to mount a Carrera engine with the clutch on. Kind of a pain to take the clutch off to do a valve job.
Old 11-30-2015, 10:34 AM
You have to take the internal oil cooler off before you attach it to the engine, it's a pain.
Spend the extra for the Porsche tool you'll be happier it holds the engine on the correct side and it's much stronger there's a lot of weight hanging off the tool. The cheaper type can distort the case. If you decide to sell it you can recover a good percentage of you investment back.
Old 11-30-2015, 10:35 AM
gtc gtc is offline
abides.
gtc's Avatar
QSC makes a P201 that works well, and it's $50 cheaper than the SIR tools P201.
Graham
1984 Carrera Targa
Old 11-30-2015, 10:41 AM
Wow! Big range of opinions. I sent a question to the eBay seller if I can install / remove the flywheel and I haven't heard back from him yet.
Old 11-30-2015, 01:39 PM
Runnin on empty
acme911's Avatar
Seller has been on the Samba for many years.
TheSamba.com :: VW Classifieds - VW Porsche 4 Arm Engine Stand Yoke - USA Made
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 11-30-2015, 02:37 PM
VFR750's Avatar
Since I've been using a p201 from our host, I can say it can hold the engine, oil cooler and clutch. It works as Porsche designed it to.
IMHO, get the right tool, even if it cost more. It makes life much simpler.
The subtle compromises of the non p201 tool add up and will irritate you when you have to pull the clutch and dump oil cooler oil just to hang the engine for some unrelated reason.
Old 11-30-2015, 03:42 PM
0396's Avatar
Our host sells two version, which one do you have? Baum @ $550+ or SIR at half the price?
Old 11-30-2015, 03:46 PM
VFR750's Avatar
I paid about $200 in 2010. Not sure which one it was.
Old 11-30-2015, 03:47 PM
It works fine on my 3.0 motor....Tim
Old 11-30-2015, 03:48 PM
VFR750's Avatar
Pel-tol-p201.
$293.25. That's what I bought
Old 11-30-2015, 03:51 PM
I have one. It won't attach to the case with the engine oil cooler in place on the oil-cooler side (as mentioned previously). I was able to install the flywheel and clutch but it was not easy. If I ever need to do this again, I intend to buy one of the better tools or modify this one so that it will fit with the oil cooler in place.
Old 11-30-2015, 04:46 PM
His photo shows the yoke mounted to the side of the engine opposite the cooler. Maybe you guys installed it wrong or it was different before?
Old 11-30-2015, 06:04 PM
Okay, so Wayne's book clearly states the yoke should be on the cooler side...
Old 11-30-2015, 06:30 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I see no weight distribution discrepancy.
I would pull the trigger.
These guys did not install it wrong. Just a clearance issue which I don't understand.
I bought the P201 from Engine Builder's Supply in 1997. $150-ish? The flywheel clamp did not fit correctly. Have yet to figure it out. Suspect the equipment is good but not the real deal? However, ignorance, even after 17 years of ownership, is very possible.
You will find ways around it.
1981 911SC Targa
Old 11-30-2015, 06:37 PM
