| Quickstep192 |
12-05-2015 03:09 PM |
Dim turn signal indicator light
I just replaced my tach after a repair and while putting all the lights back in, I noticed that when the key is on, the left indicator bulb (in the tach) glows dimly when the turn signal stalk is in the middle position. When the stalk is pushed down (left turn), that same bulb blinks brightly. When the stalk is pushed up (right turn), the right bulb doesn't light at all. I'm hoping that the dim light in the middle position is simply an indication that the right indicator bulb is burned out. Yes?
If that's correct, can someone tell me the part number for the bulb to replace it? I found a lot of bulbs in the Pelican bulb section, but it's unclear which one is for this specific purpose. 'Lil help?
Oh by the way, the bulb is in a black plastic fitting; it doesn't appear that the bulb comes out. If it does, how do you get it out without breaking it?
