Spun Rod Bearing
Other than buying a new 3.2 crankshaft what are my options ? Rod journal and rod are spun approx. 20 thou.
I'd send it out, welded up, polished, center drilled for oil to the center rods, balanced and hardened.
You can weigh the rod with everything but the bearing and call a dismantle r for a match weight or buy a full matched set here for a couple hundred. Bruce |
Buy a good std/std crank and cross-drill it. Rods are not hard to find. Save the core crank for when we can't find one anymore.
Can you recommend a shop that I can send it to ?
Ollie's in Lake Havasu AZ
Do not forget to thoroughly clean the entire oiling system otherwise this will happen again.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Have your rods checked too.
