Disabling fuel pump for compression test
My car is a '72 911T MFI. Wayne's book suggests removing the fuel pump relay before compression tests to keep from dumping excess fuel into the cylinders. I've been pouring over the literature I have available and I can't find any reference to a fuel pump relay for my model car. Can someone help me out?
Steve B.
1972 911t
1999 328is
Old 12-06-2015, 06:27 PM
SoyRacer's Avatar
Unplug the connector at the fuel pump. By left rear sway bar chassis bracket.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 12-06-2015, 06:48 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
There is actually a two plug connector inside the engine compartment near the bottom of the fuel filter. Much easier that way.
Old 12-06-2015, 08:55 PM
Thanks rattlsnak. I would rather not have to raise the car to do this.
I've looked around the area under the fuel filter and this connector is not obvious to me. Do you have a photo of the area to show me where it is?
Steve B.
1972 911t
1999 328is
Old 12-07-2015, 05:28 PM
Send a message via Skype™ to Porboynz
It can be right in the corner of the firewall to the left of the shock tower, get a torch and have a good look behind the fuel filter rather than directly under it.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 12-07-2015, 09:41 PM
rattlsnak's Avatar
^^ Just to clarify... Torch = Flashlight!!
And yes, its there somewhere and it has two wires in it.
Old 12-07-2015, 09:59 PM
Got it. It's got a brown wire and a red/green wire into a white connector.
Thanks!
Steve B.
1972 911t
1999 328is
Old 12-08-2015, 07:07 AM
