1983 SC Cabrio revival/wake up
As i mention before I bought a 1983 Red SC Cabriolet.
The previous owner wanted to part it out, but lucky I bought the whole car.
(originally with no papers, but I was able to get papers for it).
The car has been sitting for over 10 years or more.
It has no rust on body (so far only rust i found is on the back seat . It has no top so it had quite a lot of water, all the seats, under seats, carpets were soak with water.
And most of the bolts/screws are rusted. Body - perfect, original paint.
It is 100% original and has 34,300 km.
My plan is to get it running and take care of all problems after all these years sitting... and enjoy driving it
photos when i went to look at the car and got it:
Old 07-01-2015, 04:55 AM
Since I was very exciting about getting this car - I got it on the spot.
Then I brought it home ....
and started checking it.
Initial findings:
- no top (frame and canvas)
- very old gas, stinks as hell, tar about .5 inch at bottom of the tank
- all carpets are wet, rotten and falling a part
- front seats leather soaked wet on cushions and hard dry on top
- rear seats water still sitting
-dashboard warped
- seal on front window crisp/dry
- tires , thread is good but all dry and cracked
- engine missing fuel distributor
- oil S hose cracked
- engine sound insulation crisp dry and all over engine
- brakes are stuck
- and many other small things
But:
- it still looks good and powerful
more images from my garage:
Old 07-01-2015, 05:25 AM
My plan of action:
A. Water
1. take care of all the water in the car
2. remove all rotten/wet carpets and insulation
3. dry everything
B: Fuel
- drain old gasoline and try to clean the tank
- replace fuel lines
- replace fuel filters (tank and engine bay)
- replace injectors
- find fuel dist
- replace rubber fuel lines by engine
- check WUR
- check fuel accumulator (not sure how)
C : Engine
- take out engine
- clean
- replace gaskets
- clean all injector lines
- replace bad oil lines
- inspect/replace clutch
- and probably many more...
D: brakes
- remove and clean
-replace brake fluid
-replace brake lines
-replace rotors
-rebuild calipers
E: put engine back and hopefully start
After cosmetic things.
More photos coming soon.....
Old 07-01-2015, 05:39 AM
'82 SC TL
canamfan's Avatar
It sure does look pretty good considering it's been sitting outside with no roof/cover, glad you saved it! First year of the S convertible, Fuchs, guards red with red & black interior, damn...it needs to be restored, it's a beauty! Congrats & good luck!
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 07-01-2015, 05:47 AM
may I ask what you paid for it?
Old 07-01-2015, 10:46 AM
I am in Japan. Pricing here is different than other parts.
And anything you need to do - very expansive.... (unless you do it yourself).
So at the when, when i finish - should cost me about the same as market price here
but I do enjoy working on cars and it keeps me busy
Old 07-01-2015, 02:58 PM
I took all carpets and heavy duty rubber?/horse hair/padding .
There was a lot of standing water - but the only rust was under the rear seat - just surface.
Probably will not reuse any of the padding - install something new age, better for sound and thermal insulation.
The asphalt insulation was braking in pieces and quite easy to remove.
After that - 3M spray for removing glue.
Same spray to clean the super crazy strong glue used for rear seats insulation.
The leather rear seat is in good shape - needs recoloring.
photos:
and computer/controller under passenger seat - FULL of water ...
Old 07-01-2015, 03:14 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Nice move to save it.
What is the VIN? If you don't feel confortable by posting it, e-mail it and it would be dealt in confidence.
Who Will Live... Will See
Old 07-01-2015, 03:44 PM
Door panel removal:
- need to make new ones , old are bend and rotten on bottoms. Leather can be saved (good condition), but needs refinishing.
Old 07-01-2015, 04:51 PM
Gas tank removed.
It has dried tar on the bottom - after trying to clean it, impossible without splitting tank or cutting access hole .
(need to find a thread with access panel from marine tank - maybe with this mod it can be saved).
Anyway, got a tank from parts car - but needs cleaning and repainting.
Wow, old gas stinks - whole garage and house stinks .... need to move the tank outside.
new/old tank: (after a lot of scraping/cleaning old rubber paint)
After POR-15:
After will apply POR primer, and Wurth Rubber coating (black - grey not available in Japan).
Old 07-01-2015, 05:04 PM
and preparation for engine out :
1. rear bumper removal
Old 07-01-2015, 05:19 PM
Thanks to excellent Pelican members I was able to locate and buy:
- complete Cabrio top in excellent condition ( with all trimming, seals etc)
- and new Fuel Distributor
Old 07-01-2015, 05:47 PM
JJ 911SC's Avatar
I'll send you the "Test Plan" for the top, it has all the adjustment spec.
Old 07-01-2015, 05:53 PM
Engine removal continue:
Broken S-oil pipe:
Oil pipe:
Axel disconnect:
Disconnect rusted heat control boxes:
Old 07-01-2015, 06:03 PM
JJ - thanks a lot, I heard it is quite complicated to fit the complete top.
Sent pm with my email address.
Old 07-01-2015, 06:09 PM
Engine drop continue...
Disconnect wire harness plugs:
Old 07-01-2015, 06:17 PM
continue:
Disconnect fuel/oil/breather lines:
Disconnect accel link:
Remove sway bar:
Old 07-01-2015, 06:28 PM
engine drop continue:
Disconnect shift coupling and speedometer sender cable (corrected thanks to Dennis)
(forgot to slide back the rubber boot - got ripped during engine drop!)
Disconnect starter wires and trans ground strap:
and finally drop:
Old 07-01-2015, 06:47 PM
beren's Avatar
Did you get new door cores? My door cores are shot and they are linen white. Difficult to find new door cards in anything but black.
Old 07-01-2015, 06:51 PM
Door cards - will make new ones from hardboard ( local home center).
3mm thick, waterproof - used for kitchen wall paneling.
Problem is to cut to right size - old ones are very wavy and rotten...
Old 07-01-2015, 06:58 PM
